Panasonic TC-P50VT20
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P50VT20
    Originally posted by ljintexas
    Thanks for you r help. Just fixed a whirlpool Vertical Modular Washer..it needed a shift actuator and a mixing valve..I am going to remove and analyze SC..My money is on it.
    funny, it is a whirlpool. Not built to last, second control board in 2 years, absolute rubbish. good when it's working but $300 for the board.
    Totally dead. still have the old one which i suspect had a corrupted eeprom, may try a swap. If it had blink codes, I'd be right. LOL.
    could be switch but AC power is getting to it and that's it.
    the other one has one program it will run, 2 hrs and 60 deg C, we wash cold so betterthan nothing ATM
    • ljintexas
      LJinTexas
      • Jan 2015
      • 669
      Is it 120 volt?. I have a good control board
      • ljintexas
        LJinTexas
        • Jan 2015
        • 669
        Post model number of board or washer
        • tw2005
          • Oct 2011
          • 6458
          no, we're 240v . it's a front loader, wfs1285aw. control module/mainboard 481221470545. pretty sure it's not a US market item, thanks anyway
          • ljintexas
            LJinTexas
            • Jan 2015
            • 669
            Get rid of that front loader and get the top of the line top loader..The only good front loader is a commercial front loader. all of the resi front loaders have inherent issues..not all the same issues either. My board is different..Ill find someone that needs one..I ifixed this one. one bad diode and one bad capacitor..also replaced one of the relays that was iffy.
            On the road in El Paso, Tx until tomorrow..Back on the Panny tomorrow..
            • tw2005
              • Oct 2011
              • 6458
              Fixed, removed good eeprom, from DEAD board, copied and SAVED file. Removed suspect eeprom from original board 2 years ago. Compared content, corrupted.
              Reprogram with good data, reinstall and fixed.
              that board had a F14 error which i had a good idea was eeprom as only 1 program would work, rest were F14.
              I did approach Whirlpool to see if the bin file was available, needless to say never returned my cal. That's $300 board for the sake of corrupted data.
              there's a lot to be said about the old mechanical timers as opposed to micro-processor based .
              Last one was a hoover, lasted25 years with the usual wear and tear items replaced
              • ljintexas
                LJinTexas
                • Jan 2015
                • 669
                What do you make of the fact that when I remove the four screws holding the su/sd boards as directed and then check them to chassis ground as stated in the g20/g25 manual, I get infinite resistance or OL on all of the test pads? Should I be checking them to some other ground source?
                • tw2005
                  • Oct 2011
                  • 6458
                  I make you have an open cct because you don't use chassis gnd as they are not connected to it but Vfg which is floating ground tied at the SC board. The metal pads where the buffer bolts go through on the buffer board, that's your reference.Go back to the guide and look at what they show
                  • ljintexas
                    LJinTexas
                    • Jan 2015
                    • 669
                    I will review..the instructions say to remove those four screws before performing the test.
                    • tw2005
                      • Oct 2011
                      • 6458
                      page 43-44 of the G20. is that what you're following? that's what I'd be doing for buffer checks
                      • ljintexas
                        LJinTexas
                        • Jan 2015
                        • 669
                        Thats it!
                        • ljintexas
                          LJinTexas
                          • Jan 2015
                          • 669
                          Miserably shorted...also performed the shorted P15V testing as well as other testing outlined in manual..everything points to SC board and su/sd. Only one test result had a possibility of the A board being faulty. I am going to send Sc to moduslinks and buy new su/sd.
                          • tw2005
                            • Oct 2011
                            • 6458
                            can you share what you found with the buffers. like pin x - Vfg resistance etc. I am quite surprised both sd & su are coming back as shorted. I have had it on 1 V20 model I've touched so possible but it is rare overall with all the TVs I've helped and read about here.
                            • ljintexas
                              LJinTexas
                              • Jan 2015
                              • 669
                              Sure//let me go out and get my notebook.
                              • ljintexas
                                LJinTexas
                                • Jan 2015
                                • 669
                                SU41 VFO1.9 ohms, VSCN-F 219K, 5V_F124 ohms
                                SD42 VFO3.0 ohms, VSCN-F 219K, 5V_F1.7 ohms
                                VFO and 5V_F should both be in the Megohm range
                                • ljintexas
                                  LJinTexas
                                  • Jan 2015
                                  • 669
                                  So far numerous transistors and diodes bad on SC board
                                  Ordered all three from Tristate Module. Under $125 with freight..will test them before installation.
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    yeah, ok.wonder how Q661 survived normally # 1 victim but i'm glad we were thorough because the description leant towards A board.
                                    Those figures look similar too when i had a bad v20. that's the one I did not check the boards and destroyed a new SC when they were a bit more available.
                                    $125 for the 3 is good. i trust you ordered the correct revision boards as the SC and SD boards are different in the 3D.
                                    keep that core board, or sell it.
                                    • ljintexas
                                      LJinTexas
                                      • Jan 2015
                                      • 669
                                      I know for sure that SD/SU/SC are bad by the troubleshooting methods in the manual. Q660 is shot, but Q661 is okay. Found a handful of shorted diodes on it as well. On one of the logic diagrams for troubleshooting A board is listed as possible cause of failure.When I followed the shorted F15V power on procedure, it came up with SC.
                                      We will see..I am hoping A board made the trip. Previous owner replaced A Board and P board and still had 10 blinks.
                                      • ljintexas
                                        LJinTexas
                                        • Jan 2015
                                        • 669
                                        With the demand for the SC board as high as it is..i am thinking of sending it to Moduslink anyway. They will repair for $96. I can sell it for $150 without trying. I see them on all the websites for $169. But nobody has one. All are out of stock.
                                        • tw2005
                                          • Oct 2011
                                          • 6458
                                          now that info would have helped. yeah makes SC very likely.
                                          • cloo
                                            Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                            by cloo
                                            I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                            It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                            So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                            After doing a factory reset this problem was gone and the picture was back to...
                                            01-06-2025, 06:02 AM
                                          • Rensiee
                                            Panasonic TH-50PX8EA Black screen, only relay clicks
                                            by Rensiee
                                            I have been reading a few threads on here regarding Panasonic plasma tv's. I've found one thread which explains the same problem as mine, unfortunately the thread has not been completed.
                                            I got a free tv (TH-50PX8EA) from a friend which shows no screen. When plugged in only one red light shows up and when pushing the ON button, the red LED turns of and will only turn on again when pressing the ON button again.
                                            When plugging in the TV i hear two relays click fast and after a few seconds the third relay clicks.
                                            I have measured the voltage in the VSUS line, which...
                                            06-18-2024, 12:58 PM
                                          • beetle1303
                                            Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                            by beetle1303
                                            I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                            On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                            01-13-2025, 08:49 PM
                                          • CoinCoin88
                                            Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                            by CoinCoin88
                                            I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                            Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                            09-15-2025, 03:36 AM
                                          • nervx
                                            Panasonic TH-42PZ800 8-blink error mystery
                                            by nervx
                                            Years ago my tv gave a 7 blink code which turned into 8 during diagnosis. I had ordered a replacement ss board but somehow the tv started working again and i never used the board. Now a week ago my tv flickered and shut off at random and gave the 8 blink error code. The same issue it had all those years ago. The only difference this time is that over the last few months there has been some purple and green tinge that comes and goes in more solid colors such as white.
                                            Anyway i checked all the screws and replaced the ss board with a known good one and still got 8 blinks. I saw a...
                                            04-08-2022, 05:19 AM
