Vizio E421VA - no picture
  • cypress123
    Cypress
    • Oct 2015
    • 8
    Re: Vizio E421VA - no picture
    Got mine fixed, advise if you have a similar issue - if anyone reads this
    • fishmonkey
      • Jun 2015
      What was it?
      • Olympus620
        • Nov 2015
        • 21
        Someone has scatched an "X" on top of two canned capacitors on the upper right of the image. Has this TV been to a service center or has anyone else tried to fix it? Just curious
        EDIT: Sorry I didn't realize the age of this post.
        • thesnake666
          • Nov 2013
          • us
          mines had no backlight ,and like a buzzing sound comming from main board , no picture on screen , no sound, good voltages
          #solution to my problem
          hdmi ic or u501 ,72 pin ic
          silicon image ic
          i took it off smd removal and it turned right on good backlights too image on screen.
          you can either replace the mainboard with an identical board or replaced the bad ic . im replacing the ic
          • marhault
            • Jan 2020
            I know I am late to the party, but did this work? I have the same issue, but I can see the VIZIO logo then the same symptoms. I am thinking it is one of the components attached to the main board (IR, Sound, etc). Can the firmware be flashed or does the eeprom need to be replaced for that to occur?
            • cypress123
              Cypress
              • Oct 2015
              • 8
              Sorry for not responding to the reply, guess I had been watching TV, but now the same problem returns. FB4401 was blown, with that fixed, I watched tv for about 6 yrs.
              now reparing the blown fuse it just shorts the 12v to gnd, like 2 ohms or less - and it is not from my repair, no solder bridges there.
              any suggestion what it could be ? ?
              • cypress123
                Cypress
                • Oct 2015
                • 8
                [QUOTE=cypress123;1019699]Sorry for not responding to the reply, guess I had been watching TV, but now the same problem returns.
                and now I don't remember what the fix was
                • ggil44
                  Vizio M65-E0 No Picture, No Sound
                  by ggil44
                  Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                  09-03-2024, 08:30 PM
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • TR103
                  by TR103
                  - it keeps rebooting
                  01-22-2025, 04:12 PM
                • Mgiffune
                  by Mgiffune
                  I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
                  I ordered a supposedly β€˜new' Tcon board this time, and
                  06-09-2024, 10:28 AM
                • Ierwin
                  by Ierwin
                  05-13-2025, 03:31 PM
