Panasonic TC-P54VT25 Won't Turn On (Sometimes)
  • repulsion
    • May 2015
    • 5
    Howdy, folks. Hoping someone out there can shed some light on my problem, though I have a feeling I may know what the issue is.
    I have a Panasonic TC-P54VT25 television set that, more times than not, won't turn on, though if I unplug it from the back and then plug it back in, it will sometimes turn on right away, though sometimes it takes up a dozen times of unplugging and replugging to get it to work. The red blinking light doesn't abide by any of the error codes. It simply blinks, non-stop, every 2-3 seconds.
    In short: It seems as I have the same problem posted by Frank3y3 on the forum in January of last year, though I've done nothing to the TV outside of unscrewing the back to peer inside, access that the fans appear to not be the issue and give everything a dusting.
    From what I can glean, from messages on this board and beyond, it seems that it's a board issue, and that a purchase of a TNPA5081 is in my future, to which I can probably install myself using my better-than-average handyman skills. If someone, though, feels that I may be trekking down the wrong path, please let me know.
    Much appreciated.
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P54VT25 Won't Turn On (Sometimes)
    Much appreciated.
    I would have posted the link for Frank3y3, we're severely lacking in the mind reading department.
    I do recall his issue was in fact D-board for a 1 blink error.
    I'm somewhat confused with "The red blinking light doesn't abide by any of the error codes.It simply blinks, non-stop, every 2-3 seconds."
    1 blink every 2-3 seconds repeating sounds like 1 blink? How many blinks before it breaks for 2-3 secs then repeats?
    I will have to find that thread and have a re-read. I forget now if i found a way to prove A-board or D-board but next time it fails, get a hair dryer and warm the D-board only and see if you get an instant result of it turning on.
    D board will be the cheaper of the 2 boards and going on the previous thread which is same size, model and symptoms, if I was to roll the dice I'd go with D-board.
    • repulsion
      • May 2015
      • 5
      tw2005...I'm not a religious person, but bless you.
      I thought I understood the error code explanations for these Panasonic TVs...as in, I assumed when people described a one-blink error, that meant the system blinked once and then, period, it shut off. Ditto a two-blink error, seven-link error, etc.
      Yes, the light on the system blinks once, then, every 2-3 seconds, blinks again, and on and on and on. Absolutely no break...at least not up to the point that I've counted, which was about thirtysomething blinks.
      Below is the link to the post that seemed to describe my issue almost to a T.
      https://www.badcaps.net/forum/member.php?u=102222
      So the D Board is the TNPA5081?
      Thank you for the hair dryer suggestion. So if I warm that up and I get an instant result (as in the TV goes on) that definitely suggests it's the D Board?
      • tw2005
        • Oct 2011
        • 6458
        No, 5081 is the SC, did you look at all of Franky thread? D board is identifed and photos too. 5149 off the top of my head. Rev, well look at yours 2 letter stamp or maybe a sticker. I think it's center of panel below the Power supply.
        I would try warming only that board and see if it turns on. If it does not, does not mean anything either , if it does then that's an induced change.
        If a flash or eeprom chip on that is corrupted, then no number of attempts will bring it back.
        https://www.badcaps.net/forum/showthread.php?t=34593
        https://www.badcaps.net/forum/showthread.php?t=39612
        • repulsion
          • May 2015
          • 5
          Hey, tw2005, just wanted to quickly chime in and say thanks for the quick and most useful guidance last week. Admittedly, I was too lazy to find a hair dryer to heat up the D Board, but as I was more than positive that that was the problem, I went ahead and bought TNPA5081 on Ebay and am very happy to say that after replacing the part earlier today, the TV is working like a charm again. Thanks again.
          • tw2005
            • Oct 2011
            • 6458
            good to hear but I hope you mean the TNPA5149 D-board, not the TNPA5081 SC board
            • repulsion
              • May 2015
              • 5
              Oy, yes, me and my hasty cutting and pasting. Yup, the TNPA5149 D-board is what I purchased. Just wanted to clarify that in case others end up on this page looking for similar guidance.
              • tw2005
                • Oct 2011
                • 6458
                cheers
                • BigPete
                  Panasonic Heatpump Dryer Repair
                  by BigPete
                  I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                  The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                  In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                  Unfortunately the whole machine has to come apart to fix it.
                  I have...
                  11-01-2025, 06:40 PM
                • Andre Gilbert
                  by Andre Gilbert
                  11-20-2024, 08:52 PM
                • AquaMan Ua
                  Problem with PANASONIC CF53 laptop after changing BIOS settings
                  by AquaMan Ua
                  Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                  05-17-2025, 09:40 AM
                • stecos
                  Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                  by stecos
                  Hi everyone!
                  I happened several times, in the search for help from the web, to consult this very interesting forum.
                  So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                  Having said that I come to the gist of my post on the forum as the title suggests.
                  For my passion for technology I'm now collecting several...
                  11-28-2022, 11:39 AM
                • aa10aa10
                  Panasonic Toughbook CF-33 mk1 BIOS repair
                  by aa10aa10
                  Good day,
                  I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                  I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                  01-21-2025, 06:13 AM
