Pn42a450p1d
  • ljintexas
    LJinTexas
    • Jan 2015
    • 669
    Pn42a450p1d
    No standby..totally dead. Found F801 and FS801 fuses blown, MOSFETs Q801 and Q802 shorted. The IC that drives the MOSFETs, U804, has several pins grounded that should not be according to fact sheet. Also found several bad diodes nearby. Did something else cause this or is this normal wear and tear on the SMPS for an 8 yr old plasma?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Pn42a450p1d
    You might want to consider replacing the primary filter caps, ive had a similar issue where the primary caps dry out which blows the pfc diode which blows the main transistors and there respective ic's.
    • ammarben
      • May 2013
      • 63
      • algeria
      Re: Pn42a450p1d
      give us the model of power supply BN44...
      • ammarben
        • May 2013
        • 63
        • algeria
        Re: Pn42a450p1d
        U804 mc33067 pin15 vcc ,pin 4,13 gnd
        • ljintexas
          LJinTexas
          • Jan 2015
          • 669
          Re: Pn42a450p1d
          BN44-00206A
          According to the specs on the IC it's rated for 150 deg F..
          Main filter caps are barely in spec for capacitance. Pass ESR test easily.
          I bet you are correct. By the time I buy all needed components with frieght, I will spend $40
          I can get a replacement with one year guarantee for $45.
          • ljintexas
            LJinTexas
            • Jan 2015
            • 669
            Re: Pn42a450p1d
            I took the main filter caps out of circuit..One passed ESR and capacitance both. The other one failed both tests. You were right on the money Reecey!
            I ordered the replacement board with freight it was $53.
            Thanks for your advice!
            • BlackScreen_22
              Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
              by BlackScreen_22
              Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
              Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
              I had no problems connecting mosfets and capacitors,...
              08-27-2024, 12:46 PM
            • kotel studios
              Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
              by kotel studios
              Finally got time to fix this board up.
              At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
              Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
              04-22-2025, 05:08 AM
            • flerre
              Gainward Phantom GTX 980 - mosfets w/ integrated driver NCP5369
              by flerre
              Hi!
              Managed to get a Gainward Phantom GTX 980 in an auction for a bin with components.
              No video out so I started fault finding and found a blown fuse for 3 mosfets. Started checking for shorts and found what I think is a short through all of those 3 mosfets; 0.1 ohms between "VIN" input and "VSWH" output. All mosfets in this gpu are the same ones (NCP5369) with integrated drivers and when I tried measuring the other ones through these ports they were somewhere in the kilo-ohms range.
              So, could I safely assume all of these 3 mosfets are...
              03-13-2022, 12:14 PM
            • DrDos
              kenwood kr-6030 Mosfets?????
              by DrDos
              Hello everyone, I have decided to try and replace the mosfets in my power amp (the one with relay and left and right sides) on my kenwood kr-6030. I'm trying to get the A side of my speakers working. I have replaced all the caps in the power board and I thought why not change the mosfets. They seem to be working since I have great music coming out of the B side speakers and since I am not an electronic guru (but I am learning) I don't want to make any mistakes. The mosfets I have are listed A913 so I guess 2sa913 and 2sc1913. Can't really find those in mouser or digikey at least with the info...
              09-20-2025, 04:42 PM
            • NanoTesting
              Lenovo Ideapad 15IIL05, turns on and off with charger BUT works by injecting 20v after main mosfets
              by NanoTesting
              I got a 15-IIL05 that failed to turn on BUT IT DID TRY TO TURN ON and then turned off after 30+- seconds, i disassembled it and found a screw loose inside the case.
              With charger it turns on, fan spins but gives no image.
              Tested main mosfets no short, tested 3.3v,5v,DRAM, CPU etc and they were present.
              Reflashed BIOS, same problem.
              Replaced both main mosfets.
              Checked main mosfets again and i noticed that they closed once the laptop shut down, so i decided to bypass them and used a bench PSU to check how much power the laptop was drawing while trying to turn on, 20v@3A,...
              10-30-2024, 10:48 PM
