Samsung Plasma TV (PN43D450A2DXZA) -- Powers On but No Picture, 5 Blinks, Sound Works
  • colin3440
    • May 2015
    • 9
    I recently purchased a used Samsung Plasma 42” TV (PN43D450A2DXZA) from a friend and, in attempting to transport it in my car, seem to have broken it. the only physical damage is a small crack in the screen, but, when turned on, no picture appears. While I know very little about repairing electronics, I would really love to learn a thing or two and (just maybe) fix my TV in the process so I greatly appreciate your interest and patience in helping me with this project! Here's what I have so far:
    When the TV is plugged in and turned on, the red power light blinks 5 times and then goes off. No picture is displayed, but all of the normal sounds play. Also, if I plug my computer into the HDMI port and output music, I can use the TV's speakers to play sound from my computer by pressing the source button a few times.
    More Diagnostics: I took the back off the TV and tested the Va, Vsc, and Vs (I couldn't find the Ve testing point). All three were normal (Va = 58V, Vsc = -185V, Vs = 207V), but Vs starts at 207V when the TV is plugged in and then quickly drops back to 0V in about 15 seconds. I've been using Tom's fast track guide (i.e., Samsung_PN43D450A2DXZA_fast_track_guide_[SM].pdf) thus far, but am not sure how to do the part titled "activating power and logic board test patterns without main board" (it's a bit beyond my electronics skills).
    What should I do next? Do you think my TV is salvageable?
  • Shinju
    • Mar 2014
    • 1239
    Re: Samsung Plasma TV (PN43D450A2DXZA) -- Powers On but No Picture, 5 Blinks, Sound W
    Cracked screen = dead, no way to fix it and it's done. It's now good for parts.
    • colin3440
      • May 2015
      • 9
      Noooo. Alright well at least I didn't spend more money trying to fix it. Thanks!
      • noelgrund19
        • Jun 2015
        • 14
        • canada
        Was just wondering if you still have the TV and what the numbers where of the y buffer if you are going to salvage it.
        • newtothis
          • Mar 2013
          • 1556
          • england
          I wouldn't be surprised of the buffers are now shorted as the set was turned on repeatedly with a cracked screen
          • khole
            • Aug 2016
            • 3
            • usa
            I have similar issues as his. Bought TV in '11, replaced x-main in '14. Now video and audio are out, When powering up the it does play Samsung chime. I do have a very small crack in screen, it didn't break through the screen. I guess that had happened @ 3- 4 months ago. after screen cracked tv was fine for all those months , could crack be fatal for me as well? TV also shuts itself off after about 14 minutes. Haven't checked any voltages yet, would appreciate any/all input.
            • Kjelds
              • Aug 2016
              • 30
              • Denmark
              Not an expert on this, but plasma screens consists two glass substrates that are sandwiched together and sealed, the air is vacuumed out and a mixture of noble gases is injected between the glass substrates. When you crack a screen the gas leaks and the screen is dead. Maybe the gas leaked little by little since the crack incident and now its dead
              • khole
                • Aug 2016
                • 3
                • usa
                Thanks for your reply, I'm still curious as to why all my test point voltages are off or 0. Also green light on t-con board flashes every 5 seconds, constituting another problem possibly with y-main or other. Any knowledge with those symptoms?
                • maxvalutech
                  • 804
                  • australia
                  One Samsung I worked on was about 4/5 years old and had a full glass cover over screen proper and acting as a surround. It was difficult to detect cracking of the plasma screen itself. Get the voltages going and see what happens as you will learn a good bit anyway. The control board should flash regularly about once a second.
                  • KYBOSH
                    Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
                    by KYBOSH
                    Saved this beast from the landfill this weekend.
                    Manfactured July 2013 in Mexico.
                    I love working on plasma TVs.
                    Its been a while but I was lucky enough to find 2 this week.
                    The TV powers on and stays on but no picture. Havent checked for sound yet.
                    No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
                    Will start troubleshooting tonight.
                    10-17-2024, 01:17 PM
                  • KYBOSH
                    Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                    by KYBOSH
                    Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                    No picture but you hear the TV static (white noise) playing loud and clear.
                    The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                    But it seems they didn't get too far and just left it.
                    When I first took a look I was amazed at how pristine the inside looked.
                    Its as if the TV had been in a time capsule.
                    Caps looked like they were just pulled off the self.
                    Copper coils had no sign of corrosion on...
                    02-01-2023, 11:10 PM
                  • csmith
                    Vizio D50u-D1 Powers up no picture
                    by csmith
                    I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
                    Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
                    supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
                    issue. Set will power up with remote but not power off....
                    07-11-2025, 11:52 AM
                  • brithepi2k
                    Samsung UE75TU7020k No picture, Standby blinks 2 times
                    by brithepi2k
                    My Samsung UE75TU7020k lights up fine when one of the ribbon cables are disconnected from the main board, lights stay on but not getting half a picture, I do the same with the other ribbon and put the other one in and lights stay on but not getting half a picture. The standby light flashes 2 times then reboots then it then tries to come back on again and just keeps looping until I take either one of the ribbon tables out (doesn’t matter which one I take out it stays lit when either one is out). I’ve tested the backlights but all working with none shorting out, I’ve replaced the main board...
                    04-23-2025, 10:05 AM
                  • sergio_av
                    Acer Aspire E5-571G-52NH powers on, no picture. PCH_ENVDD goes off and on.
                    by sergio_av
                    Hi, I'm unexperienced with troubleshooting and I'm not sure how to proceed with this laptop.
                    Motherboard is A5WAH LA-B991P I think, i5-5200U and nvidia 820m.
                    When I received the laptop, CMOS battery had 0V. I took it out and all the testing has been done without a CMOS battery and without the main battery plugged in, I haven't been able to see physical damage, burnt or missing components with a quick visual inspection, and no shorts were found.
                    Laptop charges the battery, powers on when ON button is pressed when powered from charger and when powered from the battery, but...
                    01-01-2025, 05:27 PM
