INSIGNIA NS-LCD52HD-09 Blinking light
  • CraigR
    • Dec 2013
    • 973
    I have a INSIGNIA NS-LCD52HD-09 with the little light in front just blinks and TV never does anything. Just a steady blink and no like it's giving a code. On the power board I have 350volt at the 2 large caps but over on the connector for the 24v I get a fluctuation between 18-23volts continues and for the 5volt I get a fluctuation between 0.2-1.0volts and for the 12 volt I get 2.4 an OL rapidly. All the caps look ok also. Ideas??
  • CraigR
    • Dec 2013
    • 973
    Re: INSIGNIA NS-LCD52HD-09 Blinking light
    Anybody???
    • newtothis
      • Mar 2013
      • 1556
      • england
      On the connector from PSU to Main can you list the pin names next to them and the voltage you read at each
        Pictures of the power supply board connectors so we can see the labels for each pin.
        • CraigR
          • Dec 2013
          • 973
          readings are above post
            OK, we need to get the 5VDC STANDBY Voltage to be stable first.
            Check the capacitance and the ESR of the startup-running cap as shown in red circle.
            If you do not have the cap checker then try heating that cap with hair dryer for a few minutes then plug the TV into the outlet and see if the 5VDC will become stable at 5VDC or just replace the cap.
            • CraigR
              • Dec 2013
              • 973
              Pulled cap out and is ESR 0.10 and cap 99.44 and cap is rated 100uF @ 50Volt
                The filter caps for the 5V are also OK too?
                Try running the power supply board by itself to see if you do have steady 5V, if it is then use 47 Ohms 1W resistor to simulate about 100mA of current draw to see if it is stable, it is, then add another 47 Ohms in parallel to see if it can handle 200mA.
                • CraigR
                  • Dec 2013
                  • 973
                  That was the only cap I pulled and checked. I do have a steady voltage now of 4.995volts. But I'm unclear where you want me to hook up this resistor.
                    Between the 5V pin and the GND pin of the power supply board, no cables to the main board, we simulating the the load for the 5V power supply section.
                    • CraigR
                      • Dec 2013
                      • 973
                      Well I got a different power board and it still does the same thing so I'm guessing it's the main board. I unplugged the connector for both inverter boards and get the same fluctuating readings.
                      • CraigR
                        • Dec 2013
                        • 973
                        UPDATE: It was in fact a main board however after it turned on I found the screen broken.
                        • YasaCh
                          Sony kdl 40p5500 red light keeps blinking 3 times
                          by YasaCh
                          Hello...
                          my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                          i opened the back cover no sign of damage on the powery suply or motherboard
                          when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                          another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                          07-07-2025, 11:53 AM
                        • Fergal22
                          Samsung UE40F5300AK blinking red light
                          by Fergal22
                          I have the above tv that just shows a red light blinking twice 5 times, i have taken the back off and all the capacitors seem ok,
                          When i disconnect the mainboard from the PSU all the led's light up blinking fast but as soon as i reconnect the mainboard back to the power supply i get the red light blinking again twice 5 times,
                          I have attached pictures of the Mainboard, PSU and a small video (zipped) showing what happens when i disconnect the lead from the psu
                          Any help would be appreciated...
                          02-02-2023, 09:19 AM
                        • cajoeg
                          Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                          by cajoeg
                          Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                          The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                          02-10-2025, 04:01 PM
                        • matty24
                          Samsung UE50MU6172 - red light blinking
                          by matty24
                          Hello. I have problem with Samsung UE50MU6172.
                          TV won't turn on, red standby light is blinking.
                          Power supply BN44-00807A is fine. I replaced it with the new one.​
                          Main board BN41-02568B (BN94-12530E)
                          I've read a dump (W25Q40CL). Can someone check it od fix it for me?...
                          03-02-2025, 08:57 AM
                        • norbiszoke
                          Samsung 50AU7172, only blinking red light
                          by norbiszoke
                          We have this set here in our shop that is not ginving sign of life besides red light that is blinking one time after pressing the button and nothing more... After detaching the mainboard from the PSU (this set has separate board thank god?! or not...) the backlight comes on. After reattaching nothing besides red light.... Can anyone from the forum help me here? Thank you in advance. Here's a link with images of the mainboard and the memory IC's that are on it.
                          Regards, Norbert!...
                          04-17-2024, 06:54 AM
