Sanyo DP46849 Backlight Issues
  • Thorsbolt
    • Mar 2015
    • 22
    Picked up a 46" Sanyo from a needy family. Works great for 20 mins or so, then backlight goes out. Still have sound. Upon restarting picture shows back up for 5 min then screen cuts out. If I let it cool down it will stay on longer. Could this be CFL's wearing out and drawing to much juice when warmed up. Let me know where to start and I'll post any pictures requested.
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: Sanyo DP46849 Backlight Issues
    Pictures of all boards and overall layout, Get a clear picture of the labels next to the connector going from the PSU to main.
    We will be going through some voltage readings with a DMM to see what is dropping out when you lose the backlights
    • Thorsbolt
      • Mar 2015
      • 22
      Ok, I work till 10:00, but took some pictures before I left. I'll take it apart more tonight and get more.
      • Thorsbolt
        • Mar 2015
        • 22
        Its almost impossible to test the invertor board on this unit. The Power Supply and Video Boards bolt to the back panel and the Invertor Board bolts under the panel. Testing while powered up is going to be a task. Taking new pictures now, because I realized that some were terrible.
        • newtothis
          • Mar 2013
          • 1556
          • england
          Ignore the invertors for now, We need to check voltages on the PSU first.
          Meter set to 20VDC can you test the BL_ON pin when the backlights fail.
            • 31084
            check for cracked soldering on the power and invertor boards.
            it sounds thermal and that usually ends up being fractured soldering.
            • jetadm123
              • 2169
              As mention by stj, it appears to be a thermal problem. Try heating up each board with a hair dryer while the tv is running to see if you can accelerate the shutdown process. This will hopefully help you narrow the board that's causing the problem.
              • Thorsbolt
                • Mar 2015
                • 22
                I agree with the Thermal Diag. While working the BL On reads 3.27V DC.
                Failed it reads the same.
                • newtothis
                  • Mar 2013
                  • 1556
                  • england
                  Yeah seems to be thermal
                  • Thorsbolt
                    • Mar 2015
                    • 22
                    I'm gonna hit the power supply and video boards with a hair dryer tonight, but the invertor board is buried. Is there a good way to ohm test it?
                    • Thorsbolt
                      • Mar 2015
                      • 22
                      Better pics to help diag.
                      • Thorsbolt
                        • Mar 2015
                        • 22
                        These 3 are of the back of the power board. I see no compromised solder but I did see too slightly discolored spots.
                          • 31084
                          some bad joints there.
                          look for faint rings around the joints like a halo
                          • Thorsbolt
                            • Mar 2015
                            • 22
                            Well I can see alot of bad solder joints, what I also see is what look like something was spilled on the board. What should I use to clean it and should I focus on fixing all the solder joints or getting a new board?
                              • 31084
                              fix the joints and then clean the flux off with IPA
                              fixing joints costs nothing, so it's always worth a try.
                              • Thorsbolt
                                • Mar 2015
                                • 22
                                I fixed some solder and cleaned the board. TV still shuts down, but I am able to access the invertor now when it's powered up. Any further testing?
                                • Thorsbolt
                                  • Mar 2015
                                  • 22
                                  Also the three steel bars get exceptionally hot on the back of the power board. Like they'd burn you. I'm pretty sure the for heat dissipation. But should they get that hot?
                                  • Thorsbolt
                                    • Mar 2015
                                    • 22
                                    I ran a very low CFM fan over different boards to keep them cool and found the Main Board beneath a heat shield is getting to hot and shutting it down. It seams a finned block of metal had afoam strip on it to protect the board... It was holding heat. I removed it and the TV stays on. I'm still monitoring it. I will send a picture.
                                    • triplefour
                                      by triplefour
                                      09-13-2023, 10:43 PM
                                    • CaptainBucko
                                      Acer ER320HQ backlight issues
                                      by CaptainBucko
                                      I have two Acer ER320HQ monitors. Both have dark background (I presume backlight issues) in on the left and right hand sides of the screen. Otherwise image is clear. Can these be repaired? The monitor is supplied externally with 19v DC and I have confirmed that supply is good and stable. Any further thoughts or pointers?...
                                      12-18-2024, 06:09 PM
                                    • PJK65
                                      ASUS Q502LA LED Screen/Backlight Issues
                                      by PJK65
                                      Hello Everyone.
                                      Glad to be a member here! I am pretty new to working on laptops. I was hoping I was going to able to fix this one, but I am having some problems...
                                      This laptop works perfectly with a HDMI monitor hooked up to it. Here in lies the problem. No backlight! So i figured, replace the screen/backlight assembly. Then I had very dim video (could be seen with a flashlight) but still no backlight. Found after doing some homework that it had a blown ferrite bead, which I replaced. Like an idiot, I forgot to unplug the battery, and when I was hooking back up the 30 pin cable,...
                                      02-24-2023, 04:47 PM
                                    • DanPoka
                                      Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                      by DanPoka
                                      I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                      Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                      This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                      02-15-2025, 05:05 AM
                                    • Comp_Pro
                                      No Backlight Macbook A1990 820-01041
                                      by Comp_Pro
                                      Hello all,
                                      Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                      Tests performed:
                                      There is no backlight even with a good screen.
                                      Backlight IC is receiving the correct support voltages.
                                      Fuse F8400 ok
                                      Current sense resistor R8400 ok
                                      Backlight IC is receiving 3.3V on enable pin.
                                      Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                      Backlight IC receiving 5V from PP5V_G3S
                                      Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                      I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                      05-06-2024, 10:23 PM
