LG Won't turn on 47ld450
    Re: LG Won't turn on 47ld450
    It is a common fault with various sets & it wouldn't at all surprise me...
    Although they are not EEPROMs but flash memory that get corrupted (these words are often used interchangeably but the devices have quite a few differences.)
    • Ice203
      • May 2015
      • 99
      • Uk
      Think I might just bin the TV. Don't wanna lose and more money on it.
        Well, at least sell/give it as faulty making note of your prior diagnosis so someone else can make an attempt.
        • Ice203
          • May 2015
          • 99
          • Uk
          I'm still trying to figure out what's wrong with this on. Had 3 main boards and still same problem.
          I've got the power board out and plugged in with the 3.5v jumped to pwr on.
          I then get all correct readings apart from p-dim a-dim and inv on/off. Would this be correct as the mains not plugged in.
          • ajthatch
            • Feb 2013
            I have the same model with exactly the same issue - did you ever track down the problem? I'm thinking it could be the power supply even though the caps look good.
            • Louis82
              • Feb 2012
              • 240
              Hi.
              I have this tv that turns on and show picture for a few seconds. Power board makes a loud humming noise.
              Forced power board to turn on using resistors on PS-ON and BL-ON and I get the same thing, screen turns on for a few seconds and goes off. In those few seconds I notice shadows, like if some lamps are not turning on.
              Disconnecting screen from power board, the power board still makes a loud humming noise. My believe is a defective power board. I couldn't find any over heated component or loose connection.
              Does anybody have any suggestion on what to try before I order a new power board?
              Thank you
              • wreksta
                • Aug 2013
                • 508
                • england
                #27
                yes those inverter transformers are suspect test each one see if you get same result from each one
                had this fault and thats was the culprit
                • pajdek
                  Lenovo Y700-17ISK turn on and off
                  by pajdek
                  Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                  09-20-2023, 02:49 AM
                • RdeveLabs
                  MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                  by RdeveLabs
                  To all the members here...
                  Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                  So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                  05-05-2025, 04:59 AM
                • robante15
                  Acer Aspire 4520 won't turn on after reboot
                  by robante15
                  Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                  It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                  The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                  If I remove the...
                  04-06-2024, 06:50 PM
                • masoksian
                  Dell latitude e7470 not turn on .power buton on off and Run Power problem
                  by masoksian
                  I am dealing with the problem of turning on and off my Dell e7470 notebook.
                  The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                  The system does not turn on, there is no post.
                  I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                  The problem continues in the same way.
                  I tried to turn on the Fn key, nothing came to the screen....
                  02-15-2025, 12:08 PM
                • Ledgurra
                  MacBook Pro A1425 it doesn't turn on
                  by Ledgurra
                  hello! hope you are all well. i have a macbook pro a1425 and it won't turn on. i took it to the service center and they said it's fine, it turned on 2 times and then it wouldn't turn on. on the power supply there is a yellow dot that is charging and turns green when charging but when i turn it on it doesn't turn on. i opened it and saw on the motherboard that 2 elements are missing, i am attaching the photos for you to understand better.
                  thank you all
                  11-09-2025, 06:07 AM
