Sony KDL-42ex440 went black and slight pop from speaker
  • gates
    • May 2015
    • 9
    Last night my wife and I were watching tv and all of a sudden it turned off. We heard a slight pop from the speaker (residual sound going through speaker). Tried the remote and nothing. I unplugged tv and plugged back in, the power led turned green then pop it shut off again in three seconds (no back light).
    I removed the back of the tv and checked out the power board and everything looked good, no bad caps and the voltages all checked out under power. When I unplugged the cable going to main board the led powered up, the remote allowed me to turn it on off standby. Plugged it back in and off it went again ith no controller.
    Unplugged the Lvds cable everything went back to normal with the backlight and remote operation. So I am thinking bad T-con board.
    Thoughts?
    Thank you advance
    Corey.
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: Sony KDL-42ex440 went black and slight pop from speaker
    Pictures of your boards and overall layout.
    Voltage at Tcon fuse?
    • gates
      • May 2015
      • 9
      Here is the layout and close up of the tcon board.
      I check the fuse and could only get a slight voltage across when i plug it in for a second then it goes to zero
        Connect the LVDS cable back in place but leave the two flat white cables to the LCD out and see if the TV will turn on (there will be no pictures of course).
        Also check the DCV of both ends of the fuse with ref to the chassis.
        • sugar_ray
          • Dec 2012
          • 121
          My money's on the PS board!! But dig a little deeper before replacement
          • gates
            • May 2015
            • 9
            Lvds plugged in only and the green power light goes for three or so seconds the it shuts off. Residual pop sound through speaker.
            I only get like two or so seconds to check voltage before it all shuts down.
              So far I cannot find any service manual for this model.
                http://assets.shopjimmy.com/media/ca...255-11-top.jpg
                The white connector on the power supply board that goes to the main board has label for each pin that you need to take the DCV readings (no LVDS cable connected).
                Report the readings with the name of the pin (names of the pins MUST be included) when TV is off and when power switch is activated so we can see what is missing.
                • gates
                  • May 2015
                  • 9
                  Power board with cable between it and main board unplugged. Plugged in power turned off.
                  Ac off det = 3.3 Vdc
                  Vcc 3.3 stby = 3.3 vdc
                  Everything else is zero
                  Lvds unplugged but main board plugged in with power board.
                  Standby (red light on) / power on (green led)
                  Panel power = 0v / 12.5v
                  Audio 12v = .35v / 12.5v
                  Vcc 12v = .35v / 12.5v
                  Ground = 0 / 0
                  Ground = 0 / 0
                  Ground = 0 / 0
                  Lcd pwr = 0 / 3.2
                  BLk err = 0 / 0
                  Bl central = 0 / 1.65
                  Blkt en = 0 / 2.92
                  Ac off = 3.3 / 3.05
                  Power onoff = 0 / 3.28
                  Vcc 3.3 stby = 3.3 / 3.3
                    "Lvds unplugged but main board plugged in with power board."
                    OK, they look normal when the LVDS is not connected.
                    So what do you get when the LVDS cable is also connected?
                    • gates
                      • May 2015
                      • 9
                      That is the problem it shuts off in two or three seconds. With the lvds cable plugged in and I plug the TV into an outlet the green power led is lit up and two seconds later it goes off and no power anywhere (also hear a residual sound through the speaker when the led goes off). No red led and no light coming from the led screen.
                      Any ideas on how to test this? Is there part of the ribbon cable I could test?
                        I have a feeling that something in the T-CON board is loading down the PANEL_POWER.
                        You may be able to remove just the terminals for the PANEL_POWER and see what will happen.
                        We also verify that the LCD panel itself is not loading down the T-CON because you have already try running the TV with LVDS connected but the ribbon cables between the T-CON and the panel disconnected and it still goes into shutdown.
                        This looks like your T-CON board:
                        http://www.shopjimmy.com/sony-1-895-...-con-board.htm
                        • gates
                          • May 2015
                          • 9
                          New tcon board then correct?
                          And yes that image is the tcon board I have.
                            Yes.
                            • newtothis
                              • Mar 2013
                              • 1556
                              • england
                              How much money were we talking here? :p lol
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                • uk
                                as sj is out of stock maybe this one?
                                http://www.ebay.co.uk/itm/Sony-KDL42...item20f4adf93d
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  Lol
                                  • gates
                                    • May 2015
                                    • 9
                                    Got replacement tcom board and we are back in action. Thank you everyone for the help.
                                      Thanks for the repair follow-up.
                                      • fatcatbaz
                                        • Mar 2015
                                        • 7
                                        Just out of interest, how much did it cost for the replacement Tcon board?
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
                                          HP ProDesk 600 G5 + Bluetooth Speaker 400 ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + Bluetooth Speaker 400 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Bluetooth Speaker 400 boardview and ProDesk 600 G5 + Bluetooth Speaker 400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-12-2024, 02:30 PM
                                          HP EliteBook 830 G6 + Bluetooth Speaker 400 Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 830 G6 + Bluetooth Speaker 400 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 830 G6 + Bluetooth Speaker 400 boardview and 830 G6 + Bluetooth Speaker 400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-06-2024, 06:00 PM
                                          HP EliteBook 840 G6 + Bluetooth Speaker 400 Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 840 G6 + Bluetooth Speaker 400 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + Bluetooth Speaker 400 boardview and 840 G6 + Bluetooth Speaker 400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
