fsp223-3f01 power supply
    Re: fsp223-3f01 power supply
    Originally posted by piccy View Post
    what value would you expect r621 (bottom leg of Q601 i measured it at 0.5 ohm ? high wattage
    could i have a bad main filter cap even though it measures ok on an esr meter
    That Source resistor should be <1 Ohm, so it is OK. with bad cap it still should get boosted Voltage but may not be stable.
    So the two diodes tested OK?
    Are you able to get the P/N of the PFC IC?
      not main cap fitted one and it goes up by a volt interestingly for a brief few seconds it very quietly made buzzing (normal running type of noise) so think a poss break in a track or dry joints though no obvious ones so will have a little resoldering session
        yes two diodes tested ok
        part number i can see on chip is 1606B (the b may be an 8 difficult to make out
          maybe one of these
          http://pdf1.alldatasheet.com/datashe...I/NCP1606.html
            thanks for that will check it
            pins are marked different schematic i have
            pin1 FB
            pin2 comp
            pin3 mult
            pin4 cs
            pin5 zcd
            pin6 gnd
            pin7 drv
            pin 8 vcc
            will compare the two , have just found a schematic for fsp115-3f02 that uses a fan 7930will compare the circuits
            are there any other tests i can make round the chip that will show if it is working ?
              just resoldered a few connections on the board and there is now a intermittent faint buzz coming from the board - seems to do it for a short time then stops have warmed it with a gentle heat source seems to make no difference
                sometimes on faulty boards i give them a heat up with a hair dryer for three to four minutes if bad capacitor issue it some times get them working tempory
                  just resoldered a few connections on the board main filter cap voltage is now up to 320v and the buzzing is all the time ( normal operation type buzz ?)
                    If your AC line Voltage is at 230V, then the Voltage on the cap without the PFC booster will be = 230 *1.414 =325V.
                      so at 320v its not far away , not sure where to progress now any suggestions please budm,
                      have spotted a psu for sale in uk i may order it , i will then use that to find fault area on the original supply , bit of a cheating way wanted to get to the bottom of this the proper way
