Where can I buy transformers in UK
  • Ice203
    • May 2015
    • 99
    • Uk
    I'm in need of a transformer for a goodmans TV. Numbers on transformer are
    Mlt666bx-t2.
    Ymx-604-048.
    Can anyone help.
    Re: Where can I buy transformers in UK
    Is this an inverter transformer, or some other transformer?
    • Ice203
      • May 2015
      • 99
      • Uk
      I think it's a inverter transformer.
      Have a goodmans TV that won't turn on. But if I remove this transformer the TV works fine.
        But it can be the devices that drive the transformer are bad.
        • Ice203
          • May 2015
          • 99
          • Uk
          I done a few tests on the transformer and I'm sure it's faulty.
            Like what? How about the devices that drive the transformer?
            Pictures of the board?
            This one?
            http://www.ebay.fr/itm/MLT666BX-T1-T...item1c2c318ae2
            BTW, "Have a goodmans TV that won't turn on. But if I remove this transformer the TV works fine." so how can it work fine without the transformer? Something does not make sense here.
            • Ice203
              • May 2015
              • 99
              • Uk
              Just what I saw in YouTube. Testing ohm's.
              Will do pics tomorrow.
              • Ice203
                • May 2015
                • 99
                • Uk
                Yeah that's the board. Removed middle transformer and TV works. Very weird.
                  There is no inverter transformer on that power supply board.
                  Those two big one are the power transformers, not sure if they are for the 12V/24V supplies and if they are driven by the same circuit.
                  DRC on the primary side will show very low resistance, so you think it is shorted out.
                  Ohm meter cannot really be used to find out if the transformer is really good or bad, you can do comparison reading on the High voltage side but that does not mean if it has shorted turn it is still good because Ohm meter will not be able to show that. You need ringer for testing.
                  Need to find out how it is driven, if they are driven in parallel, and if the rectifiers in the secondary is shorted, you should check them.
                  Post good clear pictures of the connectors and the bottom side of the board. Those transformer rarely goes out.
                  • Ice203
                    • May 2015
                    • 99
                    • Uk
                    Sry. I'm new to all this so might get names wrong. On the board there are two transformers the same. I've removed the bottom one of the two.
                      I will wait for the pictures, you already check the rectifier diodes on the output side of the transformer that you removed?
                      • Ice203
                        • May 2015
                        • 99
                        • Uk
                        added a photo of a similar board as not been home yet. the transformer ive removed is circled in red,
                        just seems strange the tv works without it,
                        all the testing ive done is from what ive read on this site and your tube,
                        i also replaced the rectifier
                          Can't see any pictures.
                          Please use "Manage Attachments" feature to upload pictures.
                            The transfomers may be driven in parallel for the 24V, so if one is bad, removing the bad one will allow the power supply to function at at half power. Need to see the bottom side of the board to verify.
                              It's pretty rare to see these transformers fail because they are safety devices. If the windings burn on failure, then it can break down the insulation tape. That is at least according to the power supply guy at my workplace. So personally I would be quite surprised if the transformer were bad.
                                That is why I would like to see the good clear pictures if the bottom side of the board to figure out what is going on.
                                I myself never have to replace any power transformer yet.
                                • Ice203
                                  • May 2015
                                  • 99
                                  • Uk
                                    • 31138
                                    that's a long post
                                      The photo isn't clear enough to tell, but it looks like the transformers are connected in some kind of series or parallel arrangement. That's quite unusual.
                                        I need better focused pictures of the bottom side of the board.
                                        • caseyjay_48
                                          Sony KDL-46BX450 Inverter Troubleshoot Logic
                                          by caseyjay_48
                                          I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
                                          I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
                                          09-23-2022, 08:08 PM
                                        • amelbye
                                          is it ok to replace a dual output transformer with two single output transformers?
                                          by amelbye
                                          Hi, some prestory: I was repairing an amplifier - a "Phil Jones Bass". It had some bad capacitors an a faulty power switch. Easy job. However upon putting it back together I screwed up. The connector from the 15V-0V-15V from the transformer is identical to the audio ouput from the preamp board to the poweramp board. I ended up putting +-15VAC into the preamp outputs frying some traces on the circuit board along with the power transformer The transformer is shorted. It blows the fuse immediately even with no load on the secondary.
                                          Now that's a challenge - luckily...
                                          08-21-2020, 08:51 AM
                                        • ohren
                                          Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                          by ohren
                                          Hello!
                                          I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                          Measured voltages with no load:
                                          After rectifier diodes
                                          12V: 6.17 V
                                          5V: 5.67 V
                                          Secondary transformer pins AC measurement (really don't know if this says anything)
                                          12V: 2-2.5 V
                                          5V: 1.04 V
                                          I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                          03-18-2023, 10:33 AM
                                        • mikey5791
                                          Is it possible for transformer substitution?
                                          by mikey5791
                                          Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                                          Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                                          My questions are
                                          1. How do i test to see if the transformer is in good working condition?
                                          2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                                          Hope you guys understand what i was asking. My intention is...
                                          11-03-2022, 02:11 AM
                                        • x_orange90_x
                                          by x_orange90_x
                                          01-29-2025, 09:24 PM
