Vizio VO42L - Red Fuzz
  • mchamb
    • May 2015
    • 12
    I have a Vizio VO42L FHDTV10A with a problem that I can only describe as intermittent at best, and what happens is, the dark areas of the screen start turning red and fuzzy. I havent been able to find a whole lot of information on this through typical google searches, nor here. Im capable of testing anything that needs be tested, and probably replacing as well, I just need a starting point of what someone might think the problem is, and what i can test to verify. Attached are some pictures of the problem.
    Re: Vizio VO42L - Red Fuzz
    Did you try reseating the cable on the T-CON board?
    Need to see the pictures of the T-CON board, I would say T-CON board problem.
    • mchamb
      • May 2015
      • 12
      I hadnt yet no, but, I will most certainly crack it open and do it now! I believe from checking out the links in your signature that this is what you are referring to, correct?
      http://x.co/9SdBc
        http://x.co/9SdBc
        That is the T-CON board but there are more than one version of this TV model, your TV may not use LG LCD panel or LG panel but different version, so you need to verify.
        http://www.shopjimmy.com/catalogsear...VO42L+FHDTV10A
        • mchamb
          • May 2015
          • 12
          If you need a better Picture of a certain area, i can do that, i wasnt really sure what i was looking for, other than that nothing looked visibly fried or otherwise damaged...
            OK, this T-CON does not use the typical GAMMA IC AS15/AS19 IC.
            So did you try re-seating the cable between the T-CON and the main board?
            This is your T-CON board:
            http://www.shopjimmy.com/lg-philips-...-con-board.htm
            • mchamb
              • May 2015
              • 12
              done. it did seem kinda.... off at best.. anything else worth looking at while i have it open? problem was very intermittent so ill have to turn on and off for a day or so to see if i can reproduce it again.
              • mchamb
                • May 2015
                • 12
                Seems to be working thus far, ill post here again if it starts exibiting symptoms again
                • mchamb
                  • May 2015
                  • 12
                  seems to have fixed the problem, thanks!
                  • SS454
                    vizio e650i-a2 backlight flashes then turns off
                    by SS454
                    vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                    panel: au optronics T650HVN05.4
                    72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                    link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                    Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                    https://www.shopjimmy.com/vizio-56-0...-power-supply/
                    Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                    08-20-2020, 03:57 PM
                  • mrtek
                    Vizio M65-C1
                    by mrtek
                    Hi.
                    picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                    When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                    This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                    07-14-2025, 07:28 PM
                  • ChillingCicada
                    Vizio VO42L Issues: Need Guidance
                    by ChillingCicada
                    We've had our Vizio VO42L since before 2010, and it's worked flawlessly this entire time. However, just recently it started emitting a high-pitched buzzing/humming sound. I followed the basic troubleshooting tips of just unplugging it for a moment, and even holding down the power button while doing so, all to no avail.
                    Furthermore, after I attempted these basic steps and powered the TV back on it would always begin visually flickering while the sound stuttered. After a few moments of being turned on this would go away, but it still periodically comes back.
                    I also...
                    06-09-2021, 05:47 PM
                  • howardc64
                    Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                    by howardc64
                    Failure Symptom
                    No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                    Where is the short?
                    Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                    Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                    05-27-2025, 02:56 PM
