Insignia NS-32L430A11 / Vizio E320VL inverter transformer needed
  • mu2
    • Oct 2009
    • 217
    I have an Insignia NS-32L430A11 that needs an inverter transformer.
    The inverter / power supply board is an FSP121-2FS01
    Looks like it is also used in some versions of the Vizio E320VL. That Vizio part number is 0500-0405-1010.
    The actual part number on the transformer is 8TC00569 and I can't seem to find that exact part anywhere.
    Is there a substitute transformer available that will work?
    Maybe a more rugged version?
    The transformer has a shorted secondary.
    The photo of the transformer and board is shown in another Badcaps post
    https://www.badcaps.net/forum/showth...ghlight=e320vl
    Transformer is shown in photo #4.
    Thanks,
    Mike
    Re: Insignia NS-32L430A11 / Vizio E320VL inverter transformer needed
    It has two secondary high voltage windings, so one is shown as shorted?
    • mu2
      • Oct 2009
      • 217
      Yes,
      One winding is around 1k and the other is a lot less.
      The lower resistance winding has visibly burned windings on underside of the transformer (under the yellow tape).
      I see that Shop Jimmy has a repair kit for the Vizio board but there is no number shown on the transformer supplied.
      Mike
        That transformer is hard to find, when the winding is burnt like that can be due to the lamps are drawing too much current.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • SS454
          vizio e650i-a2 backlight flashes then turns off
          by SS454
          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
          panel: au optronics T650HVN05.4
          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
          https://www.shopjimmy.com/vizio-56-0...-power-supply/
          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
          08-20-2020, 03:57 PM
        • ohren
          Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
          by ohren
          Hello!
          I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
          Measured voltages with no load:
          After rectifier diodes
          12V: 6.17 V
          5V: 5.67 V
          Secondary transformer pins AC measurement (really don't know if this says anything)
          12V: 2-2.5 V
          5V: 1.04 V
          I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
          03-18-2023, 10:33 AM
        • mrtek
          Vizio M65-C1
          by mrtek
          Hi.
          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
          07-14-2025, 07:28 PM
        • mikey5791
          Is it possible for transformer substitution?
          by mikey5791
          Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
          Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
          My questions are
          1. How do i test to see if the transformer is in good working condition?
          2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
          Hope you guys understand what i was asking. My intention is...
          11-03-2022, 02:11 AM
