Vizio E550i-a0 no turning on
    Re: Vizio E550i-a0 no turning on
    Originally posted by jdmorgan
    So, I have this same type of TV from my father in law.
    It has the same symptoms. Will not turn on, no LED light in the bottom right.
    I have replaced the power supply (Have not check voltages).
    I have just ordered a main board. Has this been known to fix this problem???
    I hope so.
    You need to at least check the Voltages at the connector of the power supply that goes to the main board to see what is missing first.
    • jdmorgan
      • Sep 2015
      • 5
      Thanks!
      The voltage readings are as follows:
      1-2 (5.2vsb) :5v
      3,4,5: gnd
      6-7 (12v): 0v.
      8(remote on/off): 0v
      9(backlight on/off):0v
      10(pwm1):0v
      11(pwm2):0v
      12(pwm3)0v
      13(pwm4)0v
      14(pwm5):0v
      Side 4 pin Connector:
      1-4: 0
      • CapLeaker
        Leaking Member
        • 8349
        If your main board does not send PSon to the PSU, the TV will stay off.
        • jdmorgan
          • Sep 2015
          • 5
          So, hold off ordering another power supply until my replacement main board arrives?
          Sorry, EE, but not sure of the order of operational voltage on this TV.
            '8(remote on/off): 0v' The main board is not sending the ON (PS-ON same as remote on/off) command to turn on the rest of the power supply.
            • jdmorgan
              • Sep 2015
              • 5
              Thanks for the explanation.
              I'll post back after Friday when the main board gets here.
              • jdmorgan
                • Sep 2015
                • 5
                The new main board fixed it.
                • CapLeaker
                  Leaking Member
                  • 8349
                  sweet!
                  • Demetric
                    • Sep 2015
                    I started with no power.I have replace the power board,and main board.Steel no power.What next????
                      Show us good clear pictures of YOUR boards.
                      Did you do any DCV readings on the connector of the power supply board that goes to the main board to see if it at least has the standby Voltage to run the main board?
                      • Demetric
                        • Sep 2015
                        No. I just replace both boards.
                        • CapLeaker
                          Leaking Member
                          • 8349
                          well, without your pictures and not having any pin outs with corresponding voltages, I don't think we are getting very far.
                          • gfbjr52
                            • Mar 2016
                            • 7
                            I have this same model tv e550i-a0, with what sounds to be a similar issue. I turned on my tv after I got home from work. The backlight lit and I could hear the show that was on. Before purchasing anything, I thought I should ask on here first. I read through this thread and took the requested measurements. All of the voltages on the power supply checked out. I am curious as to what/where I should try to test from here.
                              Please give us the list of your Voltage readings, so far in this thread we are not getting the correct Voltages of the command signals or the power supply Voltage readings.
                              • gfbjr52
                                • Mar 2016
                                • 7
                                1-2: 5.2v
                                3,4,5: gnd
                                6-7 (12v): 11.8v
                                8(remote on/off): 3.3v
                                9(backlight on/off): 3.2v
                                10(pwm1): 3.0v
                                11(pwm2): 3.0v
                                12(pwm3): 3.0v
                                13(pwm4): 3.0v
                                14(pwm5): 3.0v
                                all 5 of the led circuits are at 27.5v with leds connected and 37.6v with the cable removed
                                4 pin
                                1-2: 0v
                                3-4: 18.2v
                                • gfbjr52
                                  • Mar 2016
                                  • 7
                                  I also checked the 2 big caps, and they read at 404v. I also have a different board than previously discussed. http://assets.shopjimmy.com/media/ca...0320-top_1.jpg
                                  • jetadm123
                                    • 2169
                                    #37
                                    Since you have a lit backlight, then try checking the mainboard for fuses (if any). Also, check the voltage regulators on the mainboard for proper output.
                                    • gfbjr52
                                      • Mar 2016
                                      • 7
                                      So just by chance as I was getting ready to check voltage regulators, I turned it on to see if the screen was doing the same thing. It was not. The left side of the screen booted as normal, the right side was mostly white, but you could see part of the vizio emblem and once it was finished you could see what channel it was on. After it was to the screen that showed there was no input the left side started pulsing from white to a perfect no input screen. The right side never changed.
                                      • gfbjr52
                                        • Mar 2016
                                        • 7
                                        Ok. I finally found a burned board. I don't know what the board is called, but it located at the bottom of the tv. It is one of the boards that the ribbon cables run to from the main board.
                                        • CapLeaker
                                          Leaking Member
                                          • 8349
                                          pictures???
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                            by sam_sam_sam
                                            07-01-2024, 06:34 AM
                                          • shamsudeen
                                            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                            by shamsudeen
                                            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                            i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                            07-19-2025, 07:14 AM
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                            I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
