Isolation Transformer for TV repair
  • tech2014
    • Aug 2014
    • 807
    I found this one on eBay, will it work for tv repair?
    http://www.ebay.ca/itm/B-K-1604-Port...item51cd02cb7c
    Re: Isolation Transformer for TV repair
    It is only rated for 1.25A, not really enough to run full load.
    May be enough to test the TV's or monitors in standby mode.
    • tech2014
      • Aug 2014
      • 807
      ok, I would rather have a better one. Any suggestions?
        • 31192
        how many W do you need?
        • tech2014
          • Aug 2014
          • 807
          doesn't matter as long as it can handle a TV.
            • 31192
            14inch lcd tv? 60inch plasma?
            • tech2014
              • Aug 2014
              • 807
              I was told 750VA is good for TV repair, 42 to 60" plasma
                • 31192
                http://na.suzohapp.com/all_catalogs/...ies/80-2000-00
                120va
                  • 31192
                  that tripplite looks seriously expensive!!
                    I use a 750VA continuous 1500VA peak iso xformer.
                    I modified it so the input and output grounds are not connected (so the chassis of the TV can be grounded or floating, useful for making measurements with a grounded scope.)
                      Also watch out and make sure it is truly isolated, some of the TRIPPLITE has Neutral tied to safety Ground.
                        • 31192
                        cant you get big isolation transformers from power-tool company's for using tools outdoors?
                        we have them in Europe, but they are 120v output (60-0-60 centertapped to earth)
                          I've seen 240V isolation transformers with "power tool" ratings, if they're the same thing. (The power tool rating is an intermittent load, about 50% duty cycle.)
                          • chrismurphy
                            • May 2014
                            • 251
                            • australia
                            Most TVs these days are have isolated power supplies and unless you are going to test the hot side,a isolation transformer is not required
                              You do need to test Voltages on the primary side such as PFC Voltage booster, the STBY Primary side drive circuit, the Inverter (for PS/INVERTER COMBO) drive ciruits, etc.
                              • chrismurphy
                                • May 2014
                                • 251
                                • australia
                                That's what I said ,but you normally use a multimeter to test those voltages
                                but you need a CRO for xysus boards etc ,in this case a isolation transformer is not required.
                                • LLLlllou
                                  • May 2011
                                  • 201
                                  You could run 3 or 4, or more, of those in parallel, should cover just about any tv's power needs.
                                  When I was about 16 and extremely short on funds (IE, had to beg for money from my parents) I bought 10 35VA 120/12 volt surplus transformers from All Electronics. Wired all the primaries in parallel, and all the secondaries in series. Made a nice 350 watt isolation transformer for like $20 bucks. Still have it today, though I don't get to use it too often anymore.
                                    http://www.ebay.com/itm/Xentek-5205-...-/111658341077
                                    • harp
                                      isolation transformer from two 240/12, wiring?
                                      by harp
                                      When is talk about making isolation transformer on poor-man way, always I see schematic 240/12-12/240.
                                      So, I wonder, is this wiring from my attachment it work, bringing some good feature or it is bad idea and why?...
                                      11-25-2022, 05:11 PM
                                    • ohren
                                      Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                      by ohren
                                      Hello!
                                      I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                      Measured voltages with no load:
                                      After rectifier diodes
                                      12V: 6.17 V
                                      5V: 5.67 V
                                      Secondary transformer pins AC measurement (really don't know if this says anything)
                                      12V: 2-2.5 V
                                      5V: 1.04 V
                                      I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                      03-18-2023, 10:33 AM
                                    • mikey5791
                                      Is it possible for transformer substitution?
                                      by mikey5791
                                      Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                                      Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                                      My questions are
                                      1. How do i test to see if the transformer is in good working condition?
                                      2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                                      Hope you guys understand what i was asking. My intention is...
                                      11-03-2022, 02:11 AM
                                    • dennis_elx33
                                      3PHASE STEP-DOWN Transformer in Check
                                      by dennis_elx33
                                      Hello All,
                                      i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                                      Problem statement: Power tripped Off
                                      Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                                      Action Done:
                                      1) Replaced the faulty parts with good spare.
                                      2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                                      12-02-2024, 06:52 AM
                                      ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                                      This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-06-2024, 04:40 PM
