RCA TV LED32B30RQ Flashing Screen
    replied
    Re: RCA TV LED32B30RQ Flashing Screen
    https://www.badcaps.net/forum/attach...0&d=1548096406
    Try removing Pin 17 (Adj = Dim).
  • Beeman2004
    replied
    Re: RCA led50b45rq screen flashes on and off
    Would that wire trick work for me as well, and which wires would I cut...pictures attached.i tried the bottom two on the tip right connector and that wasn't right.
  • jeffj7
    replied
    Just a heads up. This will get the set working but its not a fix. Sooner or later more led's are going to go bad. I've seen several tv's that were close to catching fire from led failures.
  • juandigger
    replied
    You guys are awesome. Fixed it when I thought I was screwed. Honestly thank you!
  • frodo1968294
    replied
    This worked for me after spending money needlessly on a new power supply. Thanks for the info. I would be interested to see if jb14813 's idea of using the other adj pin works.
  • elgato
    replied
    I just clipped the wire on mine. No more flashing and the picture looks great. Thanks.
    Does anyone who has been running it this way for a long time have any feedback?
    Is the actual failure the LED's or the logic board?
    It has to be a design flaw.
  • jb14813
    replied
    This worked for my tv as well the only side effect I've noticed is that the picture modes don't seem to do much anymore on mine after disconnecting the wire. I also have the 4 pin plug with two adjust and two on/off when I have time I'm going to trying hooking the wire up to the other adj pin and see if that works. I didn't cut the wire either you just pry up the little piece on the plug and slide the wire out
    replied
    Thanks for the post, keep an eye on it to see how long the LEDs will last.
  • ozzy214
    replied
    Worked for me as well. Not exact model, but damn near close. Massive flickering like a strobe, even power saver mode mentioned on one youtube couldn't save it. Just slowed it down. Cut adj wire and all good. Mine had a 4 pin connector but only 2 wires. One was led off/on other adj. The other 2 pins were off/on as well as adj just not used.. So im assuming the psu is used in multiple sets. I did notice some burning on the psu like it got hot, but tv is running fine. I love this place!
  • bimmerboy
    replied
    Worked for me!!!!! awesome!
  • TechGeek
    replied
    Could it be a mainboard issue with it suddenly jacking the voltage way up and almost forcing the failure of the LED's then cutting that wire locks the output current all the way up, dropping the voltage waaaaay down, causing the LED's to not open up due to the lower voltage which means less heat?
  • mic7
    replied
    Well add another RCA fixed With this solution. Thanks
    I can't wait to look around.
  • spaid1988
    replied
    you my friend are a god....i cant belived that worked....i pray its a long term fix
    thank u so much i cant afford a new tv
  • jrubasch
    replied
    This message is for ogad80, budm, and especially my new Hilo friend hawaiianeye. Thanks for helping me fix my RCA for free! On my tv, it was not the red wire, but the gray wire next to it that I disconnected and voila! Aloha from Aiea!
  • maharjan
    replied
    I would like to thank you for posting the picture showing which wire to dis connect. I disconnected the wire and it worked for me as well.
  • maharjan
    replied
    I found the same TV By my Apt. Dumpster. I will go and disconnect the wire as shown in the pictures. I was just wondering does it have any side effects ? i meant Power board getting hot or something else.
    thank you,
  • David1
    replied
    Originally posted by ogad80
    This is the conclusion that I came up with using your (HawwaiianEye & BudM) description. Can you guys verify this please I got 3 of these TV sitting in the closet waiting for repair. Thanks guys.
    Just to clarify, the grey with red tracer wire gets cut. I unplugged both thinking that was what you meant by disconnect, nothing happened. After trying a new pwr supply and nothing to loose I cut the wire and it works.
    Thanks for the info
  • Timmy2222
    replied
    This work great for me to thanks!!! Had this tv sitting for months!
  • alfredomfr1
    replied
    This solution work for me, too
    Thanks budm
  • ogad80
    replied
    I will get those checked but, holy crap all my three of my tvs are up and running!!!! Millions of thanks I was about to replace them now that they put them on sale this time of the year.
  • HTR-Informatique
    by HTR-Informatique
    02-09-2025, 06:51 AM
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • Chrissygizmo
    Panasonic TX-48CX350B backlights but white screen , blank screen
    by Chrissygizmo
    Hi all, I’ve got a problem I hope someone can help me fixi.
    I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
    01-11-2025, 03:18 PM
  • dicky96
    HP Elitebook Screen blank - backlights but no image
    by dicky96
    Hi guys
    I'm trying to fix this laptop screen
    Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
    OK so I have the original screen which works but has lines across the bottom quarter of the screen
    I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
    04-28-2021, 07:30 AM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
