Re: RCA TV LED32B30RQ Flashing Screen
https://www.badcaps.net/forum/attach...0&d=1548096406
Try removing Pin 17 (Adj = Dim).
Just a heads up. This will get the set working but its not a fix. Sooner or later more led's are going to go bad. I've seen several tv's that were close to catching fire from led failures.Leave a comment:
You guys are awesome. Fixed it when I thought I was screwed. Honestly thank you!Leave a comment:
This worked for me after spending money needlessly on a new power supply. Thanks for the info. I would be interested to see if jb14813 's idea of using the other adj pin works.Leave a comment:
I just clipped the wire on mine. No more flashing and the picture looks great. Thanks.
Does anyone who has been running it this way for a long time have any feedback?
Is the actual failure the LED's or the logic board?
It has to be a design flaw.Leave a comment:
This worked for my tv as well the only side effect I've noticed is that the picture modes don't seem to do much anymore on mine after disconnecting the wire. I also have the 4 pin plug with two adjust and two on/off when I have time I'm going to trying hooking the wire up to the other adj pin and see if that works. I didn't cut the wire either you just pry up the little piece on the plug and slide the wire outLeave a comment:
Thanks for the post, keep an eye on it to see how long the LEDs will last.Leave a comment:
Worked for me as well. Not exact model, but damn near close. Massive flickering like a strobe, even power saver mode mentioned on one youtube couldn't save it. Just slowed it down. Cut adj wire and all good. Mine had a 4 pin connector but only 2 wires. One was led off/on other adj. The other 2 pins were off/on as well as adj just not used.. So im assuming the psu is used in multiple sets. I did notice some burning on the psu like it got hot, but tv is running fine. I love this place!Leave a comment:
Worked for me!!!!! awesome!Leave a comment:
Could it be a mainboard issue with it suddenly jacking the voltage way up and almost forcing the failure of the LED's then cutting that wire locks the output current all the way up, dropping the voltage waaaaay down, causing the LED's to not open up due to the lower voltage which means less heat?Leave a comment:
Well add another RCA fixed With this solution. Thanks
I can't wait to look around.Leave a comment:
you my friend are a god....i cant belived that worked....i pray its a long term fix
thank u so much i cant afford a new tvLeave a comment:
This message is for ogad80, budm, and especially my new Hilo friend hawaiianeye. Thanks for helping me fix my RCA for free! On my tv, it was not the red wire, but the gray wire next to it that I disconnected and voila! Aloha from Aiea!Leave a comment:
I would like to thank you for posting the picture showing which wire to dis connect. I disconnected the wire and it worked for me as well.Leave a comment:
I found the same TV By my Apt. Dumpster. I will go and disconnect the wire as shown in the pictures. I was just wondering does it have any side effects ? i meant Power board getting hot or something else.
thank you,Leave a comment:
Thanks for the infoLeave a comment:
This work great for me to thanks!!! Had this tv sitting for months!Leave a comment:
This solution work for me, too
Thanks budmLeave a comment:
I will get those checked but, holy crap all my three of my tvs are up and running!!!! Millions of thanks I was about to replace them now that they put them on sale this time of the year.Leave a comment:
I also had corrosion/oxidation on the... -
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by dicky96Hi guys
I'm trying to fix this laptop screen
Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
OK so I have the original screen which works but has lines across the bottom quarter of the screen
I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would... -
by ChrissygizmoHi all, I’ve got a problem I hope someone can help me fixi.
I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...01-11-2025, 03:18 PM -
by reformattJust had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...07-31-2025, 08:37 PM - Loading...
