Main Cap
  • ljintexas
    LJinTexas
    • Jan 2015
    • 669
    Main Cap
    I have a smps from a sceptre I am recapping..I cannot find a replacement 100uf 450 volt cap that is the same size as the original. Its 18mm by 32 mm.
    Am I looking in the wrong places? ? Been to mouser, digikey aliexpress.
    LJ
    Re: Main Cap
    Are the dimensions critical?
    For example, could you fit one in that's a little longer, or a little wider?
      • 30978
      Re: Main Cap
      rubycon BXW series?
      • ljintexas
        LJinTexas
        • Jan 2015
        • 669
        Re: Main Cap
        I guess I could use one that is a little wider..kind of in a tight spot, laid down on the board.
          • 30978
          Re: Main Cap
          that datasheet has one 18mm x 30mm
          • ljintexas
            LJinTexas
            • Jan 2015
            • 669
            Re: Main Cap
            I found a Nichicon...A bit pricey at $5, but the right size. Thanks
            • ljintexas
              LJinTexas
              • Jan 2015
              • 669
              Re: Main Cap
              replaced nine caps including main power cap. also replaced adjustable shunt regulator that looks like a small transistor.( AZ431BZAE1 )TV is working like new.
              • Alastair E
                Chief Womble
                • Mar 2013
                • 1963
                • U.K.
                Re: Main Cap
                Cheers for letting everyone know the outcome--So many times, we hear nothing back, so dont know if any repair was successful, and what cured the problem.....
                TELEFIX
                • Dani_2024
                  by Dani_2024
                  10-28-2024, 05:06 PM
                • cheeky2
                  by cheeky2
                  05-25-2024, 03:27 AM
                • Asraf Atb
                  by Asraf Atb
                  01-27-2025, 05:02 PM
                • JSin21
                  Compatibility of main boards between different variations of samsung MU6100
                  by JSin21
                  Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                  I have Samsung Smart TV UA65MU6100WXXY version DA01
                  Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                  11-27-2023, 04:54 AM
                • jb_Bak
                  by jb_Bak
                  CN6401
                  Pin 01 NC
                  Pin 02 NC
                  Pin 03 "BL_ON": 0V
                  Pin 04 "N/C"
                  Pin 05 "STBY 3.3V": 3.5V
                  Pin 06 "GND": N/C
                  Pin 07 "AC_OFF"...
                  09-27-2021, 04:52 PM
