Main Cap
  • ljintexas
    LJinTexas
    • Jan 2015
    • 669
    Main Cap
    I have a smps from a sceptre I am recapping..I cannot find a replacement 100uf 450 volt cap that is the same size as the original. Its 18mm by 32 mm.
    Am I looking in the wrong places? ? Been to mouser, digikey aliexpress.
    LJ
    Re: Main Cap
    Are the dimensions critical?
    For example, could you fit one in that's a little longer, or a little wider?
      • 31291
      Re: Main Cap
      rubycon BXW series?
      • ljintexas
        LJinTexas
        • Jan 2015
        • 669
        Re: Main Cap
        I guess I could use one that is a little wider..kind of in a tight spot, laid down on the board.
          • 31291
          Re: Main Cap
          that datasheet has one 18mm x 30mm
          • ljintexas
            LJinTexas
            • Jan 2015
            • 669
            Re: Main Cap
            I found a Nichicon...A bit pricey at $5, but the right size. Thanks
            • ljintexas
              LJinTexas
              • Jan 2015
              • 669
              Re: Main Cap
              replaced nine caps including main power cap. also replaced adjustable shunt regulator that looks like a small transistor.( AZ431BZAE1 )TV is working like new.
              • Alastair E
                Chief Womble
                • Mar 2013
                • 1963
                • U.K.
                Re: Main Cap
                Cheers for letting everyone know the outcome--So many times, we hear nothing back, so dont know if any repair was successful, and what cured the problem.....
                TELEFIX
                • Dani_2024
                  by Dani_2024
                  10-28-2024, 05:06 PM
                • cheeky2
                  by cheeky2
                  05-25-2024, 03:27 AM
                • ygorsan
                  by ygorsan
                  🧩 Problem Summary:
                  • I
                  07-28-2025, 08:34 AM
                • Asraf Atb
                  Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                  by Asraf Atb
                  Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                  Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                  I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                  01-27-2025, 05:02 PM
                • Genghis_Khan
                  ThinkPad T470p – CMOS Checksum Error Persists After Main Battery Removal (even with new CMOS)
                  by Genghis_Khan
                  I’m currently troubleshooting an issue on my Lenovo ThinkPad T470p (Type 20J6) and would really appreciate any insights or solutions.
                  Issue summary:
                  Whenever I remove the main laptop battery and AC adaptor, then place them back, the system gives a “CMOS checksum error” at next boot, and the BIOS clock resets to its default time/date.
                  However, the RTC works fine as long as the main battery remains attached — even if the laptop is unplugged for hours. Same as I remove the battery while the AC is attached, RTC remains. Obviously,...
                  11-11-2025, 11:51 AM
