Vizio 422VA - main board?
  • phil@philporter.com
    • May 2013
    • 113
    Vizio 422VA in spare bedroom. Had not turned on for awhile. When I did the white light on button in bottom right illuminated. After about 3 seconds it starts blinking a brighter white. Found no bulging caps, but still suspected power supply. Went ahead and found one online and installed. No change - still blinking white power button light.
    Figure it must be main board, but hoping someone knows of something to try as these main boards seem hard to come by and about $100. Thanks.
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: Vizio 422VA - main board?
    Just to be sure.. All voltages present and correct on PSU?
    • mu2
      • Oct 2009
      • 217
      What version of the main board do you have? There are several.
      The number should be on the white sticker - something like TXA...... or TXB.....
      I have a main board for one of these sets that works but the version numbers must match.
      I replaced a main board recently that I believe had a corrupt eeprom - it would boot up to the Vizio logo then it would freeze. The good board that I have was a different version from the one I needed - perhaps it will match your board.
      Post your board number.
      Mike
      • ecking767
        • Oct 2009
        • 492
        I have work on a couple of the Vizio E422VA, and I found crappy caps on the power supply board. Also I had a main board that have a bad eeprom. The power LED didn't do that flashing for 20 to 30 sec. its just stay lite and no response when you press the power button.
        So maybe recap the power supply and if there is no change then its the main board
          • May 2013
          • 113
          Sorry for my delay. Had to put this project aside for awhile. Main board number is TXACB 5K00605Q.
          • newtothis
            • Mar 2013
            • 1556
            • england
            Check all voltages on PSU first
            • Dani_2024
              by Dani_2024
              10-28-2024, 05:06 PM
            • ygorsan
              by ygorsan
              🧩 Problem Summary:
              • I
              07-28-2025, 08:34 AM
            • jb_Bak
              by jb_Bak
              CN6401
              Pin 01 NC
              Pin 02 NC
              Pin 03 "BL_ON": 0V
              Pin 04 "N/C"
              Pin 05 "STBY 3.3V": 3.5V
              Pin 06 "GND": N/C
              Pin 07 "AC_OFF"...
              09-27-2021, 04:52 PM
            • JDC
              (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
              by JDC
              ONN 100012588
              Issue: No Power, Then Rebooting After Main Board Change
              Short answer: replace main board and power board
              Technical answer: replace main board and Q306 & Q307 on power board.
              Long answer:
              TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
              07-15-2022, 07:39 AM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
