possible red blinking light code, no power on samsung led tv
+ More Options
Posts
  • pctektgg
    • Aug 2014
    • 20
    I have a samsung led model un40d6000sfxza, that as of last night it simply turn off on its own and now it has no power and seems likes its trying to tell me something with blinking red light code.
    The sequence goes like this: on, on, very slight pause, on, on, very slight pause, on, on, very slight pause, on, on, very slight pause, on, on, after this 10th count it goes to a longer pause like its starting all over with the 2 at a time blinks sequence up to 10 counts again and starts all over.
    I removed back panel and visually the power board looks good, I see no burnt components, no leaking/bulging caps but thats all I currently know what to do. Im not a tv tech but I can solder and swap boards and take tv's and electronics apart just not alot experience in electronics in terms of testing parts with a meter and such. I do have a volt meter btw.
    But with directions from someone maybe I can follow if told how too. Anyone know what the blinking lights mean or know whats up? thanks
  • sordids999
    • May 2013
    • 2158
    Re: possible red blinking light code, no power on samsung led tv
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • pctektgg
      • Aug 2014
      • 20
      Ok doing that now thanks....
      heres the pictures there's 2 each for the power and main board, and one for that tcon cable I think that's what its called.
      Also got a question about fuses I see typically in tvs like this those cartridge white ceramic type fuses like this power board has how would you know if they are bad it will have a burnt black appearance to it right? It wont be mighty white right? Thanks
      • newtothis
        • Mar 2013
        • 1556
        • england
        Have a multimeter to hand?
        • pctektgg
          • Aug 2014
          • 20
          Yes I do.
          I was just readying another post on here a guy last year has same model as mine and his fix was the main board and not the power board.
          • newtothis
            • Mar 2013
            • 1556
            • england
            Well we will go through diagnosis of the PSU first anyway.
            As to testing fuses you would use ohm setting and check by testing across the fuse, >1ohm bad and <1ohm a good fuse.
            Ok set your DMM to DCV and test each pin on connector CN1. List the results like this :
            STB - 0v
            5vS - 5v
            etc
            etc
            • newtothis
              • Mar 2013
              • 1556
              • england
              Sorry forgot to say, Black probe to chassis (screw will do) and red probe to each pin in turn
              • pctektgg
                • Aug 2014
                • 20
                STB - 0v
                5vS - 5v
                etc
                etc
                Hmm so Im looking for a component on the power board that says cn1 right? I don't think I see one
                • newtothis
                  • Mar 2013
                  • 1556
                  • england
                  Outlined
                  • pctektgg
                    • Aug 2014
                    • 20
                    Outlined
                    Sorry the tv has to be plugged in and with the red front lights flashing right? btw the picture you posted is not the board i have not sure if your helping someone else and you thought I was them.
                    In the picture you gave me I see a similar connector on this board but it doesn't say cn1 says another number and in writing it has voltage readings of 1,3,5,7 etc pins it should be reading Im assuming, nothing that says stb like you said.
                      https://www.badcaps.net/forum/attach...2&d=1429748154
                      Connector CNM803A.
                      The exposed pins on top are ODD number pins, the EVEN number pins are on the bottom side of the board. The white triangle is pin 1.
                      The list of the pin names are printed on the board.
                      • pctektgg
                        • Aug 2014
                        • 20
                        Connector CNM803A.
                        Yeah I figure thats the connector he was trying to say. So i have to remove the board from tv and test all this without power and out of tv right?
                        • pctektgg
                          • Aug 2014
                          • 20
                          Check out this video same exact model code I have and same symptoms with the lights flash sequence, the fix in the video was a new led backlight part, one of the led's was burnt. Does one single burnt led cause it to not turn on?
                          https://www.youtube.com/watch?v=xsQQuiP3KAE
                          • newtothis
                            • Mar 2013
                            • 1556
                            • england
                            Sorry yes I was dealing with other threads too.
                            No it has to be in the tv connected and powered on
                            • newtothis
                              • Mar 2013
                              • 1556
                              • england
                              Yes it can if its failed open.
                              We can figure it out from voltage outputs etc
                              • pctektgg
                                • Aug 2014
                                • 20
                                Ok but the pins underneath the board do we need to test those too only the top are exposed?
                                • newtothis
                                  • Mar 2013
                                  • 1556
                                  • england
                                  I use a pin in the connector itself at the side of each wire then test against that
                                  • pctektgg
                                    • Aug 2014
                                    • 20
                                    Anyone here live can continue in helping find out what component is messed up on my tv....
                                    • newtothis
                                      • Mar 2013
                                      • 1556
                                      • england
                                      Yes when we get those voltages off the connector
                                      • pctektgg
                                        • Aug 2014
                                        • 20
                                        OK so I have to plug in and turn on the tv right? actually tv wont necessary turn on because right away from plugging it in the red light bottom right corner of the tv will start the light code sequence but maybe that's enough to test.
                                        The black probe I put against a metal screw or chassis right then touch each pin and write down the readings right?
                                        • matty24
                                          Samsung UE50MU6172 - red light blinking
                                          by matty24
                                          Hello. I have problem with Samsung UE50MU6172.
                                          TV won't turn on, red standby light is blinking.
                                          Power supply BN44-00807A is fine. I replaced it with the new one.​
                                          Main board BN41-02568B (BN94-12530E)
                                          I've read a dump (W25Q40CL). Can someone check it od fix it for me?...
                                          03-02-2025, 08:57 AM
                                        • Fergal22
                                          Samsung UE40F5300AK blinking red light
                                          by Fergal22
                                          I have the above tv that just shows a red light blinking twice 5 times, i have taken the back off and all the capacitors seem ok,
                                          When i disconnect the mainboard from the PSU all the led's light up blinking fast but as soon as i reconnect the mainboard back to the power supply i get the red light blinking again twice 5 times,
                                          I have attached pictures of the Mainboard, PSU and a small video (zipped) showing what happens when i disconnect the lead from the psu
                                          Any help would be appreciated...
                                          02-02-2023, 09:19 AM
                                        • norbiszoke
                                          Samsung 50AU7172, only blinking red light
                                          by norbiszoke
                                          We have this set here in our shop that is not ginving sign of life besides red light that is blinking one time after pressing the button and nothing more... After detaching the mainboard from the PSU (this set has separate board thank god?! or not...) the backlight comes on. After reattaching nothing besides red light.... Can anyone from the forum help me here? Thank you in advance. Here's a link with images of the mainboard and the memory IC's that are on it.
                                          Regards, Norbert!...
                                          04-17-2024, 06:54 AM
                                          09-07-2024, 05:50 AM
                                        • 3DDD
                                          Samsung UE46D6100 LED TV blinking red light indicator
                                          by 3DDD
                                          Hello, I have a Samsung UE46D6100. It cannot be turned on, only the red status LED flashes, the power supply part bn44-00458a gives an output of 5V(A), it is probably functional. I don't know where to look for the error, according to the video it should be a faulty mosfet. I found a mosfet marked WAAH, I don't know what it is. Can anyone help me?...
                                          02-20-2025, 12:51 PM
