TNPA5105 rebuild
  • tw2005
    • Oct 2011
    • 6458
    Re: TNPA5105 rebuild
    Originally posted by Alastair E
    Yup--Thats what it was, Different make 78L05 reg...
    I checked a new unused 78L05 chip, O/P to Gnd, = 5.1K I'm guessing this must be the internal pot divider for the feedback....
    Now--Finished up re-populating the heatsinks, gave the board a good going-over for any other issues and all set to go.....
    Or so I thought.
    Due to a massive brain-fart and Monumental Cock-Up on the SUS board rememberance Front, Ive found that the set I intended to use this board in has a Completely Different SC-- In fact, Its Not Even an SC, but an SN! A TNPA5066 to be exact.
    Dunno what had convinced me that this set used 5105....
    So--Ive got a rebuilt Untested 5105 and a dead 5066..... Doh!
    I'm thinking I could test this 5105 in the 42G20 that I buggered up the 5081 in, as I did an opposite swap using a 5081 in place of a 5105. A job for Sat Afternoon when the place is quiet.......
    would work as a mule but will the Sc20 ribbon make it? 5105 board is probably a good inch narrower which means the ribbon will need to go that bit further
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Ah--Good you mentioned that!
      I have a cunning plan--Grab that cheapo Argos special FHD 42" outta the garage and use the correct ribbon from that. The garage set was robbed for parts before I got it,(SN/SC PSU, SS etc Main is still there) but pretty sure the ribbon is still there too Only kept it as the panel looked good and with hope the spares may turn up...
      TELEFIX
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        I rebuilt the Original SC 5105 from this 50S21B, and tried it out.
        I used the bulb in series with Vs and checked buffers from VFO to output pins.
        --Ended up with Q661 short again and Q621 short. Bulb remained dark, after just a slight glow initially (guessed charging the SC caps--Or maybe the IGBT's dying....)
        There was no '0' VAD and VSCN was 140V, both with ref to chassis
        I'm suspecting Ive a buggered buffer--Need to check more closely. This set is one of those 'Cheapos' with no heatsinks on the buffer-chips. I think the bulb saved a lot of silicon in this case, Only two (apparently) IGBT's dead.
        Q702, Q701 read OK....
        For future reference, The supply out of IC771--Without the Reg on the board reads 100K one way and climbs to 1M the other--when all the small stuff like IC773, D702, Q702 and Transoptor etc, are good...
        TELEFIX
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          So you think possibly a bad buffer can cause this ? If so going to check mine when I get the SC on order.
          • Alastair E
            Chief Womble
            • Mar 2013
            • 1963
            • U.K.
            Yup-- Apparently a dead buffer will kill the SC...
            --Its not so much the usual shorts to the o/p pins but the small signal and the supplies to the buffers themselves--Probably lowers/kills the 5v and 16V rails which leads to the IGBT's being turned on all wrong...
            There's a test procedure on the 5081 thread, and done by TW2005--I think--that describes what to check and expected good readings....
            TELEFIX
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              #26
              Ok cheers, I have a buffer which will work from that S10B set so if my buffer is shot I will change them over. Will test it before ordering SC.
              • tw2005
                • Oct 2011
                • 6458
                Did you ever get the 5105 going?
                Just did mine finally, I missed a few things like a couple of smd resistors which were blown or out of tolerance around the drive cct Q551.
                running it in the V20 which is a struggle with the sc20 ribbon too short
                • Alastair E
                  Chief Womble
                  • Mar 2013
                  • 1963
                  • U.K.
                  #28
                  Nah--Never got back to it. Ive still got it, but had a 42" 5105 from a smashed set that I swapped all the ERC parts over from.
                  --That made that 50" set all work fine, tested it for some days, then it went into shop--Didn't last long there (50" never do), and haven't seen it since..
                  Ive got a few SC boards of various types--in various states of blowed-upness, which I'll hang onto for the future...
                  TELEFIX
                  • tw2005
                    • Oct 2011
                    • 6458
                    So here's a list of what i replaced on this board.
                    Q661,Q660,Q401,Q402,D642,Q421,Q422,IC521,R551,Q551,Q451,D482,R451
                    It's interesting on this IC773,Q701,Q702,Q818 are ok. But more damage around ic521.
                    I've also used RJP56F4A in this for the DG502
                    there is very little difference between this and the 5081
                    also a 5105 board will directly bolt into my V20 however the cabling is too short, but a 5081 would also then bolt into the S2 or U2 series and cabling would be too long which is not really an issue.
                    • mann935
                      • Feb 2013
                      • 3
                      Well there is plenty of stuff already on TNPA5105 rebuilding . I wish to share here my problem of removing and reinserting SMD parts , and I got around this using the flat heater pads that ladies use to straighten their hair . Placing those heater pads under circuit board helps removal and adding SMD parts .
                      • HJKLP
                        • Sep 2018
                        • Россия
                        #31
                        Repaired Panasonic TX-PR42U20 GPF13DE BLOCK TNPA5105.
                        Struck put
                        * Q661 (RJP63F3A), RJP63K2
                        Q401, Q402 (DG502LW), RJH30E2
                        Q422 (RJP43F4A). RJH30E2
                        And replaced the resistor R422, the resistance increased by 1 ohm.
                        Repair was limited to replacing only these elements.
                        During the initial inspection, it was found that the malfunction arose from behind the ring crack of the output of one of the transistors.
                        • andyb1712
                          • Oct 2018
                          • 41
                          • United Kingdom
                          #32
                          I recently acquired a TX-P50U20B stuck in standby with 10 flash code.
                          The previous owner had it checked at a repair centre for his house insurance and it was diagnosed as Y-SUS SC board failure. Due to the repair timescale he decided to buy a new tv.
                          I disconnected the SC from SD/SU and shorted SC50. The flash code changed to 7 and the set remained in standby, so I ordered a 15 part repair kit from eBay and proceeded to replace the blown parts.
                          On power up there was a loud crack after the main relay clicked and the set returned to standby with 10 flash code. Appears I missed something on my first attempt and destroyed my new components, plus some others too.
                          The 50" AB variant of this board is quite scarce but there are plenty of AD variants from the 42" model. I've made some comparisons using service manuals and online photos and from what I can see the AB variant has 2 additional capacitors and some big inductors in different locations. Perhaps some other parts too?
                          Has anyone successfully converted an AD variant for use in a 50" model as this looks a cheaper option than throwing more new parts onto my blown AB one?
                          I've done the cold checks on the SU/SD boards and they look good but next time I'll definitely power up with them disconnected first. Does this need to be done with the four bolts removed as well as the 3 inter connects as this is not mentioned in the service manual?
                          • andyb1712
                            • Oct 2018
                            • 41
                            • United Kingdom
                            #33
                            For anyone following this thread...
                            I acquired a TNPA5105 AD (42") and fitted C415, C631, L401, L402, L412 and L413 from my AB (50") variant, removing L401, L403, L411 and L412 from the new board in the process.
                            The board works fine in the 50" set as a result and at £30 was cheaper than throwing more new components at the original one with the risk of it going bang again.
                            • budwich
                              • Jul 2015
                              • 3097
                              its a good find / alternative. I have been wondering about the "versioning" on my tcp50s30 as the "AM" that it came with (damaged / shorted) is relatively expensive verses versions "AF" and "AJ" which look similar if not the same. So maybe your "experiment" can work for other similar "challenges".
                              • andyb1712
                                • Oct 2018
                                • 41
                                • United Kingdom
                                #35
                                Looking at the TNPA5105 there are markings on the board which indicate the capacitors and inductors that should be fitted for each size screen, 42, 46 or 50.
                                Not sure if this the same on other models as I've not worked on that many.
                                It's certainly cheaper to buy a working board from a smaller screen model and convert it for the 50 than keep throwing money at trying to repair the original board.
                                I've given up after 2 failed attempts to fix my original as I've now spent far more than the board is worth on parts. There's also the question mark over fake or recycled parts from China that are sold as new.
                                My second attempt was after a very thorough read of the TNPA5105 and 5081 repair threads and repeated checking of all parts before applying power. It still went pop again...
                                At least I have the 'converted' board and the TV is working with that.
                                • andyb1712
                                  • Oct 2018
                                  • 41
                                  • United Kingdom
                                  #36
                                  Third and final attempt at a component level repair of my original TNPA5105 and I finally got it working... for all of about 5 minutes. Then there was a loud bang and a bug chunk of IGBT shot out the back of the set and it shut to standby.
                                  I was very thorough with this rebuild and for the 5 minutes it was running, the picture was fine so I can only assume fake components (again) that aren't up to the job. I'll stick to board replacement from now on with these as it's quicker and cheaper!
                                  • reessi
                                    Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                                    by reessi
                                    Hello:
                                    I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                                    I started on the ACER:
                                    Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                                    All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                                    I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                                    10-29-2024, 11:31 AM
                                  • modtool
                                    HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
                                    by modtool
                                    Hi to all,
                                    the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
                                    I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
                                    I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
                                    04-01-2025, 08:22 AM
                                  • BalkanBoy
                                    Dead Razer Blade 14 2022, shorted CPU?
                                    by BalkanBoy
                                    today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
                                    Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
                                    I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
                                    Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
                                    I removed coil and injected 0.7V, it draw around...
                                    09-27-2024, 12:44 PM
                                  • barry101
                                    Apple 820-3662 VCore shorted to ground.
                                    by barry101
                                    Hi, Would appreciate some help.
                                    I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                                    Get charger light but no fan spin or chime. No liquid damage.
                                    Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                                    Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                                    With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                                    Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                                    06-24-2025, 07:34 AM
                                  • guizmo1967
                                    Dell Latitude 5501 LA-H181P shorted power rail
                                    by guizmo1967
                                    This is my problem:
                                    Laptop: Dell Latitude 5501
                                    Motherboard: EDC51 LA-H181P
                                    I have two power rails shorted to ground, +1.0V_PRIM and +3.3V_ALW_PCH. I removed solder on PJP302, +1.05VALWP (pad1) not shorted but +1.0V_PRIM (pad2) shorted.
                                    I also cleaned PJP38, pad1 not shorted, pad2 (+3.3V_ALW_PCH) shorted to ground.
                                    I measure the resistance of all the coils on the motherboard and they all were not shorted to ground except coil PL301 before I removed the solder on PJP302.
                                    I injected +1.05V - 2A...
                                    07-25-2023, 06:56 PM
