Magnavox 26PFL power supply
  • phil@philporter.com
    • May 2013
    • 113
    Have two Magnavox 26PFL4507/F7 tvs. Neither would power on. Purchased repair kit for power supply BA21F9F91025. Worked great for first TV. Decided to purchase the kit for 2nd TV (before I even opened the back). When I opened I found the area under the ceramic resistor badly burned (photos attached). My question - is it worth trying to use the repair kit on this board or is it too badly burnt to even try. I did purchase a new ceramic resistor in addition to the repair kit from ShopJimmy. I'm not sure what the resistors do on the back side of the burnt area and if they are gone. Thanks for any comments.
  • selldoor
    Slow Learner
    • 7870
    Re: Magnavox 26PFL power supply
    Was that a fusible resistor - I would try replacing the resistor and applying power to the board with a filament bulb in series with the +plus power - google dim bulb test.
    I also notice the fuse is missing. if the bulb lights and stays brightly lit there is a short on the board. Was the repair kit just caps?
    Small resister and diodes on the back look ok - test them?
    • CapLeaker
      Leaking Member
      • 7991
      That black bunt stuff is conductive. That has to be cut, ground or sanded away. Clean it up, replace the resistor and it should be all right.
        • May 2013
        • 113
        Thanks - will give it a try.
          • May 2013
          • 113
          Thanks. It worked great! All fixed.
          • selldoor
            Slow Learner
            • 7870
            Good to hear you got it working - if it was a fusible resistor it is important to replace it with the same type. An ordinary resistor may burn right through the board or cause damage to other components.
              by sam_sam_sam
              03-31-2024, 02:12 PM
              by sam_sam_sam
              07-01-2024, 06:34 AM
            • JimBanville
              Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
              by JimBanville
              The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
              Opened it up and discovered the power supply is making a faint clicking or ticking sound.
              I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
              I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
              09-13-2023, 07:21 AM
            • jinu_j
              by jinu_j
              Hi
              05-03-2025, 10:51 PM
