Proscan plded3992a-c flickering screen
  • mattstolte
    • Dec 2013
    • 612
    • usa
    Tv will power on but when i turn on the no signal comes on cause i dont have any connection hooked up to it, but it just continues to flash like goes on and off, this thing only has 1 board so its either this board or panel?
  • Agent24
    I see dead caps
    • Oct 2007
    • 5086
    • New Zealand
    Re: Proscan plded3992a-c flickering screen
    Can you give more explanation of the fault?
    What flashes on and off? The picture? The backlight? Everything (including power LED)? How fast does it flash (eg: how many seconds between each flash)?
    -David VanHorn
    • mattstolte
      • Dec 2013
      • 612
      • usa
      The picture and backlight. The TV led stays on though
      • mattstolte
        • Dec 2013
        • 612
        • usa
        The power led does not flicker just the screen. It stays on and the backlight flashes like every second
        • mattstolte
          • Dec 2013
          • 612
          • usa
          Im thinking it proly has bad leds
          • Agent24
            I see dead caps
            • Oct 2007
            • 5086
            • New Zealand
            Is there anything written on the board next to the connector that has the two white\red ribbon cables coming out of it? It looks like that might power the backlights?
            -David VanHorn
            • Ado02
              Lenovo Thinkpad X1 Gen 10 - Flickering Screen
              by Ado02
              We recently replaced the OLED screen on a Lenovo ThinkPad X1 Gen 10. After about a month, the replacement screen began to flicker. Initially, updating the IntelĀ® IrisĀ® Xe graphics driver resolved the issue for about a week. However, when the problem recurred, updating the driver again had no effect.
              The flickering only occurs once the system reaches the Windows login screen. Interestingly, if we disable the Intel GPU driver or connect the laptop to an external monitor, the flickering stops. We have tried installing two different replacement screens,...
              12-16-2024, 02:33 PM
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
            • reformatt
              by reformatt
              07-31-2025, 08:37 PM
            • survivalbloke
              HP ENVY HP 13-aq1013dx - screen flickering black if using touchpad or external mouse
              by survivalbloke
              SN: 8CG0213H8W
              ProdID 3C311UA
              This device came in due to the screen flickering if you use the touchpad or external mouse. It will flicker black when this occurs. If you use the touchscreen, the behavior does not appear. Also, if connected to external monitor, the external monitor is not affected by the flickering. I did a good amount of research on this, and concluded that it is due to the display driver. HP does not offer Windows 11 drivers for this model so I got the replacement drivers direct from Intel. I installed them and the problem...
              05-08-2025, 12:21 PM
            • smic717394
              by smic717394
              07-25-2024, 10:16 AM
