Tv will power on but when i turn on the no signal comes on cause i dont have any connection hooked up to it, but it just continues to flash like goes on and off, this thing only has 1 board so its either this board or panel?
Proscan plded3992a-c flickering screen
Tags: None
Re: Proscan plded3992a-c flickering screen
Can you give more explanation of the fault?
What flashes on and off? The picture? The backlight? Everything (including power LED)? How fast does it flash (eg: how many seconds between each flash)?"Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHorn -
The power led does not flicker just the screen. It stays on and the backlight flashes like every secondComment
Is there anything written on the board next to the connector that has the two white\red ribbon cables coming out of it? It looks like that might power the backlights?"Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHornComment
by Ado02Hello everyone,
We recently replaced the OLED screen on a Lenovo ThinkPad X1 Gen 10. After about a month, the replacement screen began to flicker. Initially, updating the IntelĀ® IrisĀ® Xe graphics driver resolved the issue for about a week. However, when the problem recurred, updating the driver again had no effect.
The flickering only occurs once the system reaches the Windows login screen. Interestingly, if we disable the Intel GPU driver or connect the laptop to an external monitor, the flickering stops. We have tried installing two different replacement screens,...12-16-2024, 02:33 PM -
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by reformattJust had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...07-31-2025, 08:37 PM -
HP ENVY HP 13-aq1013dx
SN: 8CG0213H8W
ProdID 3C311UA
This device came in due to the screen flickering if you use the touchpad or external mouse. It will flicker black when this occurs. If you use the touchscreen, the behavior does not appear. Also, if connected to external monitor, the external monitor is not affected by the flickering. I did a good amount of research on this, and concluded that it is due to the display driver. HP does not offer Windows 11 drivers for this model so I got the replacement drivers direct from Intel. I installed them and the problem... -
by smic717394Hi,
I have a iphone XS that came in for a screen replacement, the screen was badly cracked, and inside missing scues, on the back of the screen still the blue protector, the screen was a LCD. So we replaced the screen and all good, installed the screen and we noticed that pressing the screen with a bit of force but not excessive, the phone dies. After plugging the charger it turns back on, but again if you press it it dies. I open the phone again, and I can't see anything major, with the phone open, if I press on the logic board, battery, charging board, or even putting pressure on... - Loading...
