Wharfedale LTF42K1CB Screen problem
  • Richiiii
    • Mar 2015
    • 13
    • England
    Hi, i have a wharfedale LTF42K1CB LCD tv, it's powering up fine after a power board replacement but now i can turn it on i've noticed some strange drip like markings at the top of the screen, thay seem to grow slightly as the tv warms.
    After removing the plastic casing from the front i notice there are some tiny squares along the top edge (about six of them) on a copper strip around the screen, the drip markings seem to come from these.
    They are almost unnoticeable on light picture, on black they show as white outlines of the drips and on mid green's red's etc they appear dark, i've put a picture on if this is any help but it's quite hard to take a photo of, thanks in advance if anyone knows what they are or if they can be fixed
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: Wharfedale LTF42K1CB Screen problem
    Seen these before on other panels, Though can't remember what exactly was the cause but sure remember they are a panel fault
    • Richiiii
      • Mar 2015
      • 13
      • England
      Thanks for the reply (newtothis). I managed to get the front glass panel off the tv, i thought it might be fault with the back light or polarizing film but these seem fine. Its definitely the front glass panel (LCD part), seems like its splitting apart or something.
      • newtothis
        • Mar 2013
        • 1556
        • england
        If you check where the faults are they probably coincide with the screws that clamp the frame together
        • mmccomputer
          problem with replacing lcd screen
          by mmccomputer
          I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
          otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
          If anyone has any information on the subject...
          12-15-2024, 03:44 PM
        • jimjoe123
          LCD TV Green/Pink screen problem
          by jimjoe123
          I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
          Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
          Then each time...
          02-23-2020, 01:29 AM
        • Chrissygizmo
          Sony KD-55XG9505 lines on screen problem
          by Chrissygizmo
          Hello again everyone,
          This is my latest mission, to try getting this Sony tv back to normal working order…
          I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
          02-19-2025, 11:31 AM
        • reformatt
          by reformatt
          07-31-2025, 08:37 PM
        • smic717394
          by smic717394
          07-25-2024, 10:16 AM
