Dynex DX-LCD26-09 ---- NO 12V
  • saintlouis74
    • Dec 2013
    • 102
    I Have a Dynex unit, as soon as i plug the power cord up i get 6 blinking red light then when i press the power button it turns green and screen stays black.. I dont hear any clicking from relays.. i tested all diodes and resistors everything looked good.. VCC tested ok
    But the 12v reading isnt solid, i get a high reading then it starts dropping. could be the cheap multi meter im useing.. but i cant seem to find the 12volts
    any help in guiding me in the right direction would be appreciated alot thanks
    Re: Dynex DX-LCD26-09 ---- NO 12V
    Is the 24VDC out to the inverter board steady? The 12V and 24V are generated by the same big transformer, the 12V is down converted by BUCK CONVERTER IC904 that converts 24V to 12V.
    Try disconnecting the inverter board to see if the 12V becomes stable.
    http://www.shopjimmy.com/insignia-ad...pply-unit.htm#
    • saintlouis74
      • Dec 2013
      • 102
      the 24v is not steady just keeps decreasing, unplugged the inverter and still no steady 12v
        That is what I expect as I explain that the power source for the 12V and the 24V is from the same power transformer.
        Lets see if the PFC Voltage booster is OK or not, you will be working in the primary deadly side of the circuit so do not touch anything with your hands, you need to check the DCV between the two legs for the main filter cap (100uF 450VDC) to see if it has >360VDC when power switch is activated, it should be quite steady Voltage.
        You can also try heating the whole board with hair dryer for 2~3 minutes to see if the 12V/24V will become steady.
        • saintlouis74
          • Dec 2013
          • 102
          that is what i expect as i explain that the power source for the 12v and the 24v is from the same power transformer.
          Lets see if the pfc voltage booster is ok or not, you will be working in the primary deadly side of the circuit so do not touch anything with your hands, you need to check the dcv between the two legs for the main filter cap (100uf 450vdc) to see if it has >360vdc when power switch is activated, it should be quite steady voltage.
          You can also try heating the whole board with hair dryer for 2~3 minutes to see if the 12v/24v will become steady.
          394vdc
            That is fine, so the SMPS for the 12v/24v may not be getting steady VCC to run the SMPS IC.
            So did you try hair dryer yet?
            • saintlouis74
              • Dec 2013
              • 102
              hell yea your the best... heating up the board did the trick... i got a 24v and 12v back.. the TV even powered up.. so what do i need repair for this to be fixed?
                OK, just try heating the suspected cap (the one I marked with 'SUSPECTED' by itself or replace it, I would replace the whole set of caps any way.
                • saintlouis74
                  • Dec 2013
                  • 102
                  replaced them all.. its back up and running thanx a ton
                    That is fast. Thanks, glad it was just bad caps.
                    • SCCronauer25
                      Dynex tv with model #32L200a12 turns on, but shows "please wait..." quickly...
                      by SCCronauer25
                      I am trying to fix my Dynex tv. The PSB is new and so is the Control Board, but when I turn it on, I get "please wait..." on screen, then it quickly goes black. I have the back of it off and checking voltages shows 5v standby and 2.5v supply comes on going away/into PSB/Control Board, 24v is present on PSB (getting .4v on most, if not all, backlight lines, 5v to backlight is there also), the control board's heatsink staying hot to the touch, plus the 2.5v going away/into the PSB/Control Board, gives me the impression it is on. What else should I check for?
                      07-02-2022, 02:34 PM
                    • tvtimmy
                      Dynex DX-24L230A12 no power
                      by tvtimmy
                      Check power supply for bad(puffy) capacitors. I found 4 1000uf caps bloated. Replaced and all is good again.
                      11-07-2021, 01:14 PM
                    • itronic
                      Dynex dx-40l261a12 wont power on.
                      by itronic
                      This model Dynex DX-40L261A12 tv will not power on. The standby light comes on and the PSU makes a clicking noise when power cord is plugged in. But thats all.
                      Connection point with power cord plugged in on PSU.
                      I'm thinking PSU but like other inputs. Thanks in advance.
                      Xp805:
                      gnd
                      gnd
                      stb
                      5v---4.8v
                      5v---4.8v
                      12v
                      12v
                      gnd
                      bri
                      sw
                      gnd
                      gnd
                      5v_m
                      5v_m
                      If i unplug XP1 on mainboard and jump 5v to stb is will click and you will hear the speakers come on then fade...
                      01-22-2020, 01:59 PM
                    • bigbeark
                      Dynex 350 Watt PSU self-starts
                      by bigbeark
                      I was troubleshooting my Asus A8V motherboard (Socket 939). Finally got everything working except the board would start up as soon as the power switch on the PSU was turned on ie without pushing the motherboard power button. The Onboard sound was crackly so I tried a PCI-slot sound card. This didn't work at all and when I moved it to the lowest PCI slot the board would not boot. I swapped the PSU out and everything worked
                      fine with the replacement PSU, even though it had less power on the 12V rail.
                      I took the cover off, no obvious faults. I took time to read the PSU faqs....
                      01-17-2021, 11:28 AM
                    • csmith
                      Vizio D50u-D1 Powers up no picture
                      by csmith
                      I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
                      Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
                      supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
                      issue. Set will power up with remote but not power off....
                      07-11-2025, 11:52 AM
