Dynex DX-24L230A12 no power
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Check power supply for bad(puffy) capacitors. I found 4 1000uf caps bloated. Replaced and all is good again.
  • PantherDave
    by PantherDave
    Hi all!
    05-29-2024, 02:01 PM
  • GLISIT
    by GLISIT
    01-16-2025, 02:29 PM
  • bcstedt
    LG 42LB5D, 42LB5DF-UL, 2008-01, Power On Issue, Replaced PS Caps
    by bcstedt
    LG 42LB5D (42LB5DF-UL) from 2008-01, unit is in good shape and no obvious heat damage or cracked solder on the boards.
    Problem:
    On first power-up the power LED flashes green about 18x and then stays solid. No backlight or image is present. Click power button, wait 10s for a click and the LED turns red. Wait 1-2s and hit power again and maybe it'll power up fully after 6 green flashes. If it doesn't light up on the sixth flash then the cycle repeats.
    It seems that if the mainboard power is left on for a few minutes (solid green power, no backlight, no image)...
    01-18-2024, 01:03 PM
    03-31-2024, 02:12 PM
  • MicroSMD Lab
    MSI MS-16W1 no power, EC replaced by other.
    by MicroSMD Lab
    Hi, I'm working on a MSI laptop, Motherboard number MS-16W11, GF-65 Thin 10SDR-459US. Went to another shop because the screen was flickering, but it was working well on an external monitor. The LCD was ordered and the laptop was returned to the customer and it no longer worked. It was then sent to another tech (by the shop who ordered the LCD) and the EC (ENE KB9028Q) was replaced with a donor from another MSI board with different board number and no programming was done. It looks like work was done on PU6 (TPS51225) as well as one of the GPU mosfets was burnt (I removed all three GPU mosfets)....
    03-27-2025, 07:35 AM
