Another 50PJ350 Supply Problem
  • Merc
    • Jan 2015
    • 18
    Repairing for my niece. Turn on and I hear the relays, screen flashes, cuts off.
    I find one of the two 22 ohm resistors on power supply board is open. I temporarily outboard some power resistors to see it it works. It does. Let it run. Order new 22ohm 5W. Install, test and send on its way. It's DOA at her house.
    Second try. I get it back. Same 22ohm is open again. I order a kit from eBay with resistors, regulator, diode.... Install and it works again. I keep at home this time turning it on and off and then just letting it run some.
    After 2-3 days I go turn it on and it's back to just clicking again.
    I did notice on another thread on this site about this model that I may have to up the wattage of the 22ohm power resistors due to the display pulling more current as it ages. Is this correct? Has this cured this issue for anyone?
    Thanks,
    Merc
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: Another 50PJ350 Supply Problem
    Go with a 10w
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8352
      maybe you didn't selected the correct resistor (high pulse current rated)? If you replace it, does it get hot? Is that resistor limiting the inrush current or what does it do? Maybe some pics etc?
      • paulstef
        • Dec 2013
        • 724
        If it is the EAY60968701, I recently made a video about this:
        https://www.youtube.com/watch?v=NmifFBrB8BM
        And if it is the resistor I think it is there is only current through it for a very short amount of time the moment M_ON turns off.
        The ones you used may not be rated for that current. On the EAY60968801 two resistors are connected to VS via a MOSFET. That means 200V on about 44Ohm.
        You may want to increase the wattage, the resistor may not have enough pulse power rating.
        • Merc
          • Jan 2015
          • 18
          I have two 22ohm 10W ordered. I'll put those in and test it for a while before sending on. Set is too heavy to haul back and forth.
          I think I saw your video if you posted the schematic you drew. Thanks.
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
            03-31-2024, 02:12 PM
          • unimatrix93
            Identifying backlight resistors, power supply is a BN44-00852
            by unimatrix93
            Dear forum, I would like to ask some help identifying the backlight circuits resistors to limit the ampere to the backlight leds.
            The power supply is a BN44-00852 and I want to decrease the backlight to increase the lifetime of the LEDs.
            The TV is pretty much always on, used for CCTV cameras.
            I suspecting R9838 -> R9841 resistors but I'm not sure. Thanks in advance!
            04-29-2024, 04:49 AM
            07-01-2024, 06:34 AM
          • shamsudeen
            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
            by shamsudeen
            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
            i know that in linear power supply the noise will be very low comparing to SMPS supply....
            07-19-2025, 07:14 AM
