42ln5400 dead.
  • Rickig
    • Mar 2015
    • 112
    • England
    42ln5400 dead.
    I have the above mentioned lg tv
    It was completely dead. I removed back and replaced fuse on main board. Now I get red light when on standby. When taking out of standby it flashes 2 times and goes out, no backlight nothing.
    Any ideas
  • Hamie
    • Apr 2014
    • 1383
    Re: 42ln5400 dead.
    Put the mainboard in the oven for for 10-15 mins.
    Remove then heat gun it.
    Ghetto reflow.
    • Agent24
      I see dead caps
      • Oct 2007
      • 4950
      • New Zealand
      Re: 42ln5400 dead.
      if the fuse was blown, probably something else is also blown. Look over the board for burnt\damaged components.
      -David VanHorn
      • Rickig
        • Mar 2015
        • 112
        • England
        Re: 42ln5400 dead.
        Nothing looks bad. Couple FEts testing oc so Ordered a new psu off eBay only £15 so swap that first.
        • Rickig
          • Mar 2015
          • 112
          • England
          Re: 42ln5400 dead.
          Fitted new psu. No change. Refitted old psu.
          Stripped screen and found 2 duff led. Repaired the leds and got back light working but found I have sound and backlight but nothing on lcd. 12v to tcon.
          Ordered a tcon as there cheap enough but wondered if it's more likely to be a main board fault?
          Any advise welcome
          • Lukkas
            • Apr 2012
            • 7
            • Slovakia
            Re: 42ln5400 dead.
            do you have some result with your repair? I have same problem :/
            • fharris1977
              Vizio D50u-D1 Dead Set No Standby
              by fharris1977
              Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
              12-28-2023, 10:25 AM
            • thstuff
              Sony OLED XR-77A80J - Initially dead, now 4 Flashes
              by thstuff
              A) TV initially dead
              B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
              C) Was able to perform a Reset from Settings menu and completed out of box configuration.
              D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
              E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
              12-26-2024, 09:10 PM
            • jacobtc
              LG C1 65'' dead standby
              by jacobtc
              I've owned this C1 from new since late 2021, and it has now suddenly started with the following symptom:
              If power has been connected for a while, the red standby lamp turns off, and the tv wont turn on (no reaction from remote or button on tv).
              If power has been disconnected for 5 minutes, the tv turns on fine, until turned off and left for a couple minutes, as the standby light will then turn off again.
              I've seached and found that this is most likely a failing PSU, and I've seen repair services on eBay fixing these symptoms, so I am hoping that someone here has fixed...
              01-29-2025, 04:27 AM
            • dellxps15
              macbook a1707 15 inch trackpad dead. blown fuse identification
              by dellxps15
              hi all, got this macbook with dead trackpad. after some investigation i found that fuse is bwlown. it's marked with a K on it. anyone kjnow it's value ? it is a 0402 package.
              another problem is: i tried another trackpad that was working fine, but the feedback sensor was not. all volts are present, but the click mechanism isnt .
              04-30-2024, 10:48 AM
            • mecha1166
              QN750Q8FNBFXZA Service Error Codes Needed - Error code 1-3-1-2 ? Dead set, only blinking standby light in repeating sequence
              by mecha1166
              I am working on a QN750Q8FNBFXZA. Dead except the standby light. It blinks what appears to be 1 3 1 2. 1 long blink, pause, 3 short, pause, 1 long, pause, 2 short, pause, repeat. A service manual would be very helpful, or if anyone knows these error codes. Thanks!
              03-28-2024, 08:31 AM
