LG 42LN5700 stuck on lg logo
  • tvnewbie2
    • Apr 2015
    • 8
    • united states
    Found this TV on the curb. It's in beautiful shape but can't figure out it's issue.
    I read somewhere that baking the main board at 385deg for 10 min fixes the issue I'm having.
    But it did not fix the issue. I called LG and they're no help at all.
    I've tried baking the main board for 10 min at 385deg
    I've tried unplugging the TV for 5 min
    I've tried unplugging the TV and holding the power button while it's unplugged to drain caps
    I looked inside no visiable blown caps and all fuses are testing good.
    Anyone have a clue on what it could be? There's only 4 boards in the TV two big and two little.
    The power board looks fine. Main board looks fine and the WiFi card looks good, and there's the Yvonne board I think it's called . All looks fine.
    Anyone have any ideas? I'd post pictures but I think a video would benefit more so I'm going to take one now and post it .
    Thanks for the help. I seen lots of fixed tv's come from this forum. I hope mine is one of them
    LG 42LN5700 stuck on startup: http://youtu.be/B68lKvjaCa4
    Here you go guys.
  • tvnewbie2
    • Apr 2015
    • 8
    • united states
    Re: LG 42LN5700 stuck on lg logo
    I found a main board for $60 on eBay I'm thinking of ordering. If I do do you think it may solve the issue?
      Most likely, it's the main board. It's the most common issue when TVs appear to be stuck on some screen or freeze/lock up. One trick I've found sometimes helps is to gently heat up the flash memory chip - this part gets corrupted, causing the fault - heating it up seems to temporarily allow the data to be extracted correctly, enough for the TV to boot up.
      • tvnewbie2
        • Apr 2015
        • 8
        • united states
        What does this chip look like for my tv? I ended up hunting Around and im buying a main board for $35 shipped. Hopefully it works. But id like to try and see if i can fix this at home first.
        Its one of those i want to do it just to see if it works type thing.
        • tvnewbie2
          • Apr 2015
          • 8
          • united states
          So come to find out i wont the main board for $30 with $9.50 shipping. So $39.50 for a $120.00 boardi hope it works!
          • StinkyOnion
            • Dec 2015
            • 6
            Did it work?
            • nwcs
              • Dec 2015
              • 311
              • usa
              I have repaired many of these tv's and yes it is the main board.
              • kevinm34232
                • May 2012
                • 1884
                Does this look like a main board issue on this same model LG?
                • freakaftr8
                  • Oct 2012
                  • 3743
                  Yes. Do you see trhis same image every time you power up the tv? What happens when you change inputs or press the menu button? Any movement of the purple bars?
                  • kevinm34232
                    • May 2012
                    • 1884
                    Don't have the TV yet this is a pic I was sent by customer.. I'll update when I get it, thanks!
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                    • duwane
                      MacBook Air A2337 - 820-02016 - Stuck at 5v - Varying current draw - Board had short
                      by duwane
                      Hi All.
                      I have an 820-02016 board (A2337 M1) that has come in for data recovery. Reported as liquid damage, but no visible evidence of any liquid damage.
                      Board was initially stuck at 5v, and current only spiking occasionally to around 400mA and cycling.
                      After initial troubleshooting, found that C7800 (which feeds the power rail PP5V_BSTLQ_VOUT_SPMU) was dead short to ground.
                      Replaced C7800 and short gone. Board still stuck at 5v. Current draw behaviour changed. It now spikes up for a second to around 100mA to 130mA, then drops down to...
                      10-17-2023, 07:48 PM
                    • x_orange90_x
                      Vizio V555-G1 stuck on wallpaper; now stuck on V logo
                      by x_orange90_x
                      I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
                      12-28-2023, 06:26 AM
                    • mferna14
                      Apple 820-01958-A logic board stuck on 5V .19amp
                      by mferna14
                      Hi friends, working on a MacBook Air A2179 logic board 820-01958-A logic board. It's just stuck on 5V .19amp on one USB-port & then when I use to the other port it's also stuck on 5V .19amp but on this port it resets after few secs & start over with the same said voltage. I assumed that one of the CD3217B12s is defective, & replaced both with known good ICs. The status & result remains the same. I checked for shorts or liquid spill, all clear. On F8400 there is 12v present, but no 5V or 3.3 volts. There are LDO voltages on the both CDs 3.2v & 1.5V. Kindly if someone can help...
                      02-21-2025, 03:42 PM
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
