Sanyo LCD-40R50F lcd tv shorted mainboard - need help
  • jackal68
    • Mar 2014
    • 91
    Re: Sanyo LCD-40R50F lcd tv shorted mainboard - need help
    With that IC off the board, it the short gone now?
    I guess, at this point, I might as well take it off and see if the short is gone. If I use hot air, I am assuming this board would be safe, correct?
    • CapLeaker
      Leaking Member
      • 8192
      either that, or you can cut the legs off with a knife and get rid of the leftovers on the pads with solder wick.
      • jackal68
        • Mar 2014
        • 91
        Well, I finally took out the main chip (the burnt one)...and the short went away!! I guess that was the problem.
        Now, how/where do I find this chip to purchase? Can I use another chip?
        any ideas?
        thanks
        • CapLeaker
          Leaking Member
          • 8192
          best idea I can come up with is to look for the IC on Aliexpress or some other china mart, or look for a "universal lvds board" and convert the TV.
          • jackal68
            • Mar 2014
            • 91
            Budm cited a site that has a main board available, but they want a hefty $65US plus $25 shipping. At this point, I'm unwilling to put in $90US into this tv.
            I found this site that has three ic numbers for the same chip. Are they all compatible??
            RTD2932 RTD2933H RTD2934S
            http://www.aliexpress.com/store/prod...0.0.0.0.Bggzzh
            • CapLeaker
              Leaking Member
              • 8192
              There are many sellers that sell that chip. So specify the one you need to the seller, or look for a different seller.
              • jackal68
                • Mar 2014
                • 91
                After buying from a seller from Aliexpress and paid through paypal over a month ago, I still did not receive this chip. I eventually had to open a dispute through paypal and got my money back.
                Back to the drawing board to get this chip.....still looking.
                • Dani_2024
                  by Dani_2024
                  10-28-2024, 05:06 PM
                • ygorsan
                  by ygorsan
                  🧩 Problem Summary:
                  • I
                  07-28-2025, 08:34 AM
                • jb_Bak
                  by jb_Bak
                  CN6401
                  Pin 01 NC
                  Pin 02 NC
                  Pin 03 "BL_ON": 0V
                  Pin 04 "N/C"
                  Pin 05 "STBY 3.3V": 3.5V
                  Pin 06 "GND": N/C
                  Pin 07 "AC_OFF"...
                  09-27-2021, 04:52 PM
                • JDC
                  (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                  by JDC
                  ONN 100012588
                  Issue: No Power, Then Rebooting After Main Board Change
                  Short answer: replace main board and power board
                  Technical answer: replace main board and Q306 & Q307 on power board.
                  Long answer:
                  TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                  07-15-2022, 07:39 AM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
