Vizo L32HDTV10A No digital input on main board
  • 102mm
    • Dec 2013
    • 181
    • us
    So i picked up this Vizio from the dump today. It turns on and works except for the HDMI and the DTV. the weird thing is when i go to the menu and attempt to do a channel search the OSD goes away and the TV is unresponsive but i can still turn it off. All other menu options work until i get to the Channel setup sub menu. I've checked the voltage regulators on all the main board and the digital board and they all are ok. Any Ideas? The Main Board P/N: 3370-0072-0150, Digital Tuner P/N:3370-0052-0187
    Digital Tuner
    Main Board
    Craigslist Picks & Fixes
    2 ea - Samsung 52"
    Samsung 60"
    Re: Vizo L32HDTV10A No digital input on main board
    I would at least check the Voltages of the regulator ICs to start with.
    • 102mm
      • Dec 2013
      • 181
      • us
      I checked all the 1117 voltage regulators on the main board and the digital board. they all seem fine. I'll check the smaller ones tonight. I need to figure out what controls the digital portion of the TV. there is a separate sub-menu for that portion. that's where it locks up
      2 ea - Samsung 52"
      Samsung 60"
      • mykolas
        • Mar 2014
        • 18
        • usa
        I know it was a long time ago, but did you ever find the answer to this problem?
        I've been offered the same set with the same problem. Don't want to waste my time if it wasn't worth the trouble.
        Mykolas
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          A solutions/recommends are:
          1. Acquire and update the Firmware.
          2. Replace the Main Bd. if available.
          I would go for the 2nd option, as it may be easier.
          • mykolas
            • Mar 2014
            • 18
            • usa
            I picked up the set, picked the "dtv" option from the input source. Went to the menu to select "tv" option the screen goes blue and the menu disappears. Can not get the menu back unless you turn the set off.
            Tried to find the firmware update on the Vizio website but no luck finding it.
            I considered replacing main but if the board does not have the latest upgrade I'll be back to square one.
            Asking to see if someone on the list would know where to get the upgrade(if one exists).
            Thanks for looking,
            Mykolas
            • Dani_2024
              by Dani_2024
              10-28-2024, 05:06 PM
            • ygorsan
              by ygorsan
              🧩 Problem Summary:
              • I
              07-28-2025, 08:34 AM
            • jb_Bak
              by jb_Bak
              CN6401
              Pin 01 NC
              Pin 02 NC
              Pin 03 "BL_ON": 0V
              Pin 04 "N/C"
              Pin 05 "STBY 3.3V": 3.5V
              Pin 06 "GND": N/C
              Pin 07 "AC_OFF"...
              09-27-2021, 04:52 PM
            • JDC
              (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
              by JDC
              ONN 100012588
              Issue: No Power, Then Rebooting After Main Board Change
              Short answer: replace main board and power board
              Technical answer: replace main board and Q306 & Q307 on power board.
              Long answer:
              TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
              07-15-2022, 07:39 AM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
