Samsung PS50A656T1F clicking
  • Andyd1970
    • Feb 2013
    • 374
    • united kingdom
    Hi Guys,
    Just taken in a Samsung PS50A656T1F, you give it power and you hear the PSU click to switch on, most of the time it does not come on and occasionally it does switch on and you can watch it.
    I have just been trying it and it has switched on 5 times no problem, I cannot see an bulging or leaking caps on the PSU.
    Any ideas
  • PowerAmpFreak
    • 982
    • Sweden
    Re: Samsung PS50A656T1F clicking
    Check if PSU has 7815 regulator (common fault solder joints)
    Also, check the two TO220 transistors (on the primary side in the smaller of the two LLC converters) on the heatsink for bad solder (veeery common)
    It's little hard to see, which PSU it is, but I think it's the one.
    • Andyd1970
      • Feb 2013
      • 374
      • united kingdom
      Hi, Thank you for the info, please see pic of the PSU, can you please help with the location of the components you mentioned.
      The PSU number is BN44-00222A, 20080112, WF3.5 REV1.0
      Thank you
      • PowerAmpFreak
        • 982
        • Sweden
        See areas within red boxes
        • Locutor13
          • Oct 2013
          • 61
          Hi, I was experiencing something similar with the same PSU. It kept clicking without turning-on, the problem was a cracked solder joint of one of the legs of one of the black relays. You will find those relays just above the main fuse. Also you can check the solder joints in that area, it looks like that area gets really hot.
          In my case a reflow of that joint solder brought my PSU back to life.
          • Andyd1970
            • Feb 2013
            • 374
            • united kingdom
            I did the first reflows as suggested by PowerAmpFreak and it seemed to be OK, but I left it on for about 30 minutes, powered it down by the standby button on the front of the TV. I was just repairing a laptop and the PSU in the TV was just clicking all by its self! how spooky.
            • PowerAmpFreak
              • 982
              • Sweden
              Keep on searching for more bad joints...
              • Andyd1970
                • Feb 2013
                • 374
                • united kingdom
                Hi, I have reflowed the two relay in bottom left, also scanned PCB and reflowed most of the components but nothing was obviously dry. I had it running for an hour and I heard it start clicking on its own so can only assume it powered its self down?
                I left it a while and tried to power it up again and the relay clicks around 5 times ish and them stops and if you touch standby button on front nothing happens.
                Help!
                • PowerAmpFreak
                  • 982
                  • Sweden
                  Then it sounds more like the mainboard is shutting off the PSU.
                  Hook up a meter to the PS_ON signal and see.
                  • Andyd1970
                    • Feb 2013
                    • 374
                    • united kingdom
                    OK,
                    Just measured it at the PSU end and it switches between 0.660v to 3.475v.
                    Am I right in saying that is should be 5v?
                    Andy
                    • Andyd1970
                      • Feb 2013
                      • 374
                      • united kingdom
                      I have checked over all other PCB's and cannot see any damaged components, I have also given it a clean up as it was pretty dusty and fluffy inside.
                      • PowerAmpFreak
                        • 982
                        • Sweden
                        As the PSU starts to click you can see the PS_ON is syncronized to clicking?
                        In that case - mainboard shuts it off.
                          Are you saying the 5V STBY is going up and down?
                          You should check the two small startup-running, filter caps (4 small LYTICS caps) next to that TO-220 Power MOSFET (in red box) for that standby power supply.
                          And do not touch any heat sinks since some of then will be have line voltage on it.
                          • PowerAmpFreak
                            • 982
                            • Sweden
                            The measurement was meant to be on the PS_ON signal. (Not +5V STBY)
                            But of course, first you must have +5V STBY to be able to switch on the rest.
                            • Andyd1970
                              • Feb 2013
                              • 374
                              • united kingdom
                              Hi I did measure it on the PS_ON pin on the PSU. I will do the other measurements suggested by BUDM and get back to you.
                              • Andyd1970
                                • Feb 2013
                                • 374
                                • united kingdom
                                Hi BUDM, How do I measure the caps as you cannot get to the legs as under the PCB?
                                  You need to remove the caps and check the capacitance and the ESR.
                                  Try heating that area with hair dryer to see if the 5VSTBY becomes stable, it it does then I would just replace the caps.
                                  • Andyd1970
                                    • Feb 2013
                                    • 374
                                    • united kingdom
                                    OK great I have a ESR meter
                                    • PowerAmpFreak
                                      • 982
                                      • Sweden
                                      You are talking about different things here.
                                      Andy measured that mainboard cycles the PSU by PS_ON.
                                      He have not (yet) verified if +5V STBY is stable or not. Would be first thing.
                                      Based on your findings I would focus more on diagnosing the mainboard or perhaps jumping the PSU manually on PS_ON to see if it stays on.
                                        Ahh, I read post 10 wrong, now I see that he is referring to the PS_ON not the 5V line.
                                        "Just measured it at the PSU end and it switches between 0.660v to 3.475v.
                                        Andy"
                                        • nath1977
                                          Samsung F7000 occasionally cycles and fails to switch on
                                          by nath1977
                                          I have a UE40F7000 Samsung which occasionally fails to properly come out of standby. The relay clicks and the backlight flashes but then goes off again with a click, and repeats. I think its temperature related as leaving it overnight seems to allow it to switch on OK.
                                          I assume its PSU related and had a look - it's a BN44-00632B. No signs of swollen caps or hot components.
                                          I saw a great YouTube video on a possible PFC related issues and an underrated resistor https://youtu.be/DREofE4WIvg?feature=shared though a quick trace from the SPC7011F pin 7 lead me to a resistor...
                                          12-27-2024, 11:10 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
