Vizio e601i has no backlight
  • fixerupper75
    • Oct 2014
    • 125
    • us
    Re: Vizio e601i has no backlight
    Question I have seen alot of these board with yellow boxes(if you will). Is there a known problem with the grey ones.
      I do not know but I know that they do fail (either grey, yellow, white, or blue) in capacitance value (capacitance goes down).
      • fixerupper75
        • Oct 2014
        • 125
        • us
        E=1.16
        f=1.15
          E=1.16
          f=1.15
          OK, so they are good, 1uF.
          I need to do more tracing then. I really do not expect the two caps will show 0V when the TV is fist started since there is no open transformer or inductor windings.
          Can you please verify for sure?
          • fixerupper75
            • Oct 2014
            • 125
            • us
            Nothing on the those 2. The blue disc looking thing. What is it and I did a resistance reading on it and got 12M ohms and open now.
              The 4 blue disk on the board? They are X/Y Safety caps.
                OK, the next thing to test will be the resistance between the chassis and each pin of the LED connector, the plug will have to be removed first from the board before testing the resistance. We are trying to find out if any one of the wire is shorted to the chassis.
                • fixerupper75
                  • Oct 2014
                  • 125
                  • us
                  #28
                  The four on the right read 0 ohms and the four on the left read high resistance. I checked this yesterday. But couldn't remember the numbers. I'm beganning to think the led on the first ones are bad.
                    Did you check the resistance readings of the plug with the 8 grey wires removed and the readings are from the 8 grey wires against the chassis? They are not the resistance readings on the connector on the board right? because there are < 1 Ohms resistor on the board that are connected to GND (CHASSIS).
                    I will not be surprised if you have bad LED but we want to make sure there is not shorts to the chassis due to the wires to the LED strips are cut or nicked, that is why you need to remove the connector from the board first and check the resistance of those 8 wires against the chassis.
                    • fixerupper75
                      • Oct 2014
                      • 125
                      • us
                      #30
                      Yeah, that's what I did removed the 8 pin connector and checked each one to chassis gnd. the wires going into the panel.
                        OK, unless I am wrong, none of them should show any resistance to the chassis.
                        You can try measuring the Voltages on those four caps we did earlier to see if all 4 caps will show Voltage readings now on the two legs of each cap.
                        • fixerupper75
                          • Oct 2014
                          • 125
                          • us
                          #32
                          Ok ill check tomorrow. If I get voltage on the 4 caps does that indicate bad leds.
                            If you do get the Voltages on the caps, then I would say the wires going into the panel is nicked some where by the chassis so you get the resistance readings, bad led will not cause the shorts to the chassis.
                            • fixerupper75
                              • Oct 2014
                              • 125
                              • us
                              #34
                              Hey Budm,
                              Thanks for your help. But the person i was troubleshooting this decide to have Vizio repair it, for a much larger fee, of free.
                                Ah too bad, sure like to find what the cause of the problem is, thank for letting us know. If you can get a hold of the person and find out what they did to fix it, that will good.
                                • Wackyracer
                                  • Mar 2015
                                  • 23
                                  I am working on the exact same model with a similar problem....the LED side lights are bad. My customer bought some used on ebay on my diagnosis. They arrived today. Plugged them in and there was light.
                                  Now to disassemble the panel to replace the bad ones.
                                  • Wackyracer
                                    • Mar 2015
                                    • 23
                                    My guess is Vizio will replace the panel to fix the failed led side lights.
                                    • Wackyracer
                                      • Mar 2015
                                      • 23
                                      Anyone have a source showing how to disassemble this large panel?
                                      I have done some smaller ones with ccfl back lights.
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 5091
                                        • New Zealand
                                        #39
                                        You may find some video on YouTube or such
                                        -David VanHorn
                                        • Wackyracer
                                          • Mar 2015
                                          • 23
                                          Been there...That's why I'm asking as I am unable to locate the info myself.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • SS454
                                            vizio e650i-a2 backlight flashes then turns off
                                            by SS454
                                            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                            panel: au optronics T650HVN05.4
                                            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                            https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                            08-20-2020, 03:57 PM
                                          • 1crow1
                                            Vizio E601i-A3 backlight issue
                                            by 1crow1
                                            When I turn on the TV the backlights flash on for a second and go out, I get the Vizio logo on screen for that short time. It passes the flashlight test.
                                            Will a bad backlight cause this shutdown or should I be looking at the power board.
                                            CN301 CONNECTOR
                                            Readings as follows
                                            VLED1-1+ 125 volts then drops to 0
                                            VLED1-1- 0 volts
                                            VLED1-2+ 0 volts
                                            VLED1-2- 109 VOLTS THEN DROPS TOO 0
                                            VLED2-1+ 105 volts then drops to 0
                                            VLED2-1- 0 volts
                                            VLED2-2+ 0 volts
                                            VLED2-2- 130 volts then drops to 0
                                            CN201 reading seem...
                                            03-22-2023, 07:11 AM
                                          • Fly_Among_Stars
                                            VIZIO E70-E3 Half picture with half TCON
                                            by Fly_Among_Stars
                                            I have a VIZIO E70-E3.
                                            Symptoms: Black screen, no picture, but LED backlights are working.
                                            I probed the power board and voltages are as listed on the board.
                                            Main board appears fine, too.
                                            I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                                            There are two separate ribbon cables feeding the LCD.
                                            If both are connected, the screen is black.
                                            If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                                            04-24-2023, 08:20 PM
                                          • Yanleb
                                            Vizio M70-D3 4K with dark spots backlight issue
                                            by Yanleb
                                            I have a Vizio M70-D3 4K with a dark spots backlight issue. It is using the Y8387248A backlight driver board.
                                            On this model each of the 64 transistor powers 2 LEDs. Using my TKDMR TD3H backlight tester I've determined that the backlight LED strips were the issue, and the backlight driver board was just fine. Some LED pairs required 5.9 volt at 155mA, some required 9.5 volt and some were completely open.
                                            I've removed the LCD panel and once the LED strips were exposed I've tested them again by connecting my LED tester directly on the test pads. To my surprise all, I've...
                                            03-22-2022, 01:06 AM
