Vizio e601i has no backlight
  • Agent24
    I see dead caps
    • Oct 2007
    • 5093
    • New Zealand
    #41
    Re: Vizio e601i has no backlight
    Ah, ok. I have not done a large one myself either but I have done LCDs\CCFLs up to 22", I expect there is not a huge difference. Maybe the panel frame is different but overall it should be similar.
    -David VanHorn
    • Wackyracer
      • Mar 2015
      • 23
      The led strips have been replaced. Found that one of the 2 strips had a couple of leds that you could see were burned out.
      To dis assemble the panel, once the back of the tv is removed, start with the screen facing you. This will aid in aligning all the diffusers on reassembly.
      Have someone help you with the glass and have a brand new dust cloth to remove any dust that may get on the surfaces....I used one made by Guardsman.
      • Agent24
        I see dead caps
        • Oct 2007
        • 5093
        • New Zealand
        #43
        Good to hear and thanks for the information. I definitely agree about the dust!
        -David VanHorn
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • SS454
          vizio e650i-a2 backlight flashes then turns off
          by SS454
          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
          panel: au optronics T650HVN05.4
          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
          https://www.shopjimmy.com/vizio-56-0...-power-supply/
          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
          08-20-2020, 03:57 PM
        • 1crow1
          Vizio E601i-A3 backlight issue
          by 1crow1
          When I turn on the TV the backlights flash on for a second and go out, I get the Vizio logo on screen for that short time. It passes the flashlight test.
          Will a bad backlight cause this shutdown or should I be looking at the power board.
          CN301 CONNECTOR
          Readings as follows
          VLED1-1+ 125 volts then drops to 0
          VLED1-1- 0 volts
          VLED1-2+ 0 volts
          VLED1-2- 109 VOLTS THEN DROPS TOO 0
          VLED2-1+ 105 volts then drops to 0
          VLED2-1- 0 volts
          VLED2-2+ 0 volts
          VLED2-2- 130 volts then drops to 0
          CN201 reading seem...
          03-22-2023, 07:11 AM
        • Fly_Among_Stars
          VIZIO E70-E3 Half picture with half TCON
          by Fly_Among_Stars
          I have a VIZIO E70-E3.
          Symptoms: Black screen, no picture, but LED backlights are working.
          I probed the power board and voltages are as listed on the board.
          Main board appears fine, too.
          I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
          There are two separate ribbon cables feeding the LCD.
          If both are connected, the screen is black.
          If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
          04-24-2023, 08:20 PM
        • Yanleb
          Vizio M70-D3 4K with dark spots backlight issue
          by Yanleb
          I have a Vizio M70-D3 4K with a dark spots backlight issue. It is using the Y8387248A backlight driver board.
          On this model each of the 64 transistor powers 2 LEDs. Using my TKDMR TD3H backlight tester I've determined that the backlight LED strips were the issue, and the backlight driver board was just fine. Some LED pairs required 5.9 volt at 155mA, some required 9.5 volt and some were completely open.
          I've removed the LCD panel and once the LED strips were exposed I've tested them again by connecting my LED tester directly on the test pads. To my surprise all, I've...
          03-22-2022, 01:06 AM
