Sharp LC37SB24u won't stay on
  • jakeklem
    • Feb 2015
    • 42
    I need some help tracking down an issue with this set. I've found that a few of the CCFL are not lighting, but there are other issues it seems. I have the inverter board disconnected from the PSU. It will power on and I can see (with a flashlight) the menu flicker on the screen, but it only appears for a second. Then one of three things will happen. TV goes dead and I get the green blinking light, it will stay on but no menu, or it turns red then I get the amber light if I try to power it back on.
    voltages on the PSU when it stays on:
    13v: 13v
    BU5v: 5v
    PS_ON: 3v
    Can anyone suggest a starting point on fixing this one?
    Re: Sharp LC37SB24u won't stay on
    "I've found that a few of the CCFL are not lighting" It will only take one bad CCFL, or bad Inverter transformer or circuit to put the TV in protection mode, so if you know that it has bad CCFL, then you need to replace it or bypass the protection circuit at you own risk.
    • jakeklem
      • Feb 2015
      • 42
      Does it go into protection mode if the inverter is disconnected?
        Do you mean the cables going to the inverter board are disconnected or the cables to the lamps?
        It depends on the design.
        You also need to look at the inverter board connectors to see if there are any labels for the pins to tell you what the pin's functions are.
        • jakeklem
          • Feb 2015
          • 42
          I mean the little bridge between the power board and the inverter is disconnected.
          yes, there is labeling on the inverter board connection from the PSU. see attached picture.
          Getting 64v on the 60v pins.
          • CapLeaker
            Leaking Member
            • 8283
            Looks like we can see only every other pin out, not all of them. There is more behind the connector
              Please list all the pin names.
              • jakeklem
                • Feb 2015
                • 42
                Oops, I missed that. Here it is.
                • jakeklem
                  • Feb 2015
                  • 42
                  How might I bypass the protection mode? I want to see if it will stay on without the CCFL.
                  • jakeklem
                    • Feb 2015
                    • 42
                    I get voltage after power on until it goes into protection mode. Here is the pin out to the inverter board:
                    GND 0
                    STB 3v
                    OFL 0
                    OSC 0
                    ERR 0
                    REGBRT 0
                    NC 0
                    ADMIN 0
                    NC 0
                    13V 13v
                    GND 0
                    NC 0
                    GND 0
                    GND 0
                    NC 0
                    GND 0
                    no label 0
                    NC 0
                    60v 64v
                    60v 64v
                    60v 64v
                    60v 64v
                    • CapLeaker
                      Leaking Member
                      • 8283
                      if you disconnect the inverter from the PSU, does the TV work normal less the back light?
                        It does per post 1.
                        I do not see the BL-ON signal pin on that list of the pin out.
                        Also the dim control signals and other signals also showing 0V which do not look right.
                        • jakeklem
                          • Feb 2015
                          • 42
                          Briefly yes, but it will not stay functional.
                          • jakeklem
                            • Feb 2015
                            • 42
                            Originally posted by budm
                            It does per post 1.
                            Yes, good observation Bud. I wonder if the pin without a label might be BL-ON.
                            Any ideas for a starting point of what I can test? Is there a way I can fake out the circuit protection to make it act like the inverter is plugged in?
                            I haven't messed with backlights much. What would happen if I remove the ones that are not functioning and power it on?
                              OK, I look at the inverter board picture at Shopjimmy, I see that it has a rectangular box fuse F7501, and also a bunch of power MOSFETs mounted on the heatsink, so you should check them out to see if any of the MOSFETs is shorted out or not.
                              http://www.shopjimmy.com/sharp-runtk...-inverter.htm#
                                OK, this is what I found, I look up the power supply board at Shopjimmy:
                                http://www.shopjimmy.com/sharp-rdenc...upply-unit.htm
                                According to SJ, this power supply board is also used in LC-37D44U (the other 3 models do not have good service manuals for them).
                                So I found the service manual at ELEKTROTANYA:
                                Page 70 show the pinout of the LB connector, the STB (Von) is the BL-ON and you do have 3V there so BL-ON is OK.
                                You said you see blinking LED, so see the manual to see if the code match your blinking LED.
                                It is big manual and I did not have the time to look at everything in details yet.
                                  LCD LED TV Service Menu Codes
                                  ALL LCD LED TV SERVICE MENU CODES
                                  Service Menu Code with Board Name
                                  China Universal Board / Jumper Board Service Menu Code
                                  Changhong Ruba Service Menu Code
                                  Ecostar LED TV Service Menu Code
                                  Orient LED TV Service Menu Code
                                  Haier LED TV Service Menu Code
                                  TCL LED TV Service Menu Code
                                  Samsung LED TV Service Menu Code
                                  LG LED TV Service Menu Code
                                  Videocon LED TV Service Menu Code
                                  Supra LED TV Service Menu Code
                                  Toshiba LED TV Service Menu Code
                                  Symphony LED TV Service Menu Code
                                  Veste/ LED TV Service Menu Code...
                                  10-31-2024, 03:58 AM
                                • ttmi100x
                                  HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                                  by ttmi100x
                                  Greetings everyone,
                                  I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                                  The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                                  Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                                  Upon closer inspection...
                                  07-31-2024, 06:36 PM
                                • AustinComputerDoctor
                                  Sharp CC-60LE640U - after mainboard replacement, backlite turns on -- but cannot update firmware / see menu
                                  by AustinComputerDoctor
                                  I am looking / wondering if anyone knows where a good firmware download link is for a LC-60LE640U, the sharp support sight says the screen is archived but offers no links.
                                  I see backlite is active,
                                  but I cannot get the screen to return back to menus , etc
                                  This is all after replacing the mainboard...
                                  any assistance is greatly appreciated.
                                  03-25-2024, 12:43 PM
                                • mikey5791
                                  Help on Samsung Syncmaster T220 dead ccfl lamp
                                  by mikey5791
                                  This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
                                  Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
                                  10-18-2020, 03:17 AM
                                • Retro140
                                  Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
                                  by Retro140
                                  So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
                                  To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
                                  06-18-2023, 06:13 PM
