Philips 50pfp5532d stuck on standby
  • Hughes07
    • Jul 2013
    • England
    Just looking for a little help here. I've got a philips 50pfp5532d which stopped turning on. I opened it up to see 4 bulging capacitors and 2 leaking so thought easy fix. I've replaced almost all capacitors on the board though other than the bigger ones but still no luck.
    When it's plugged in it sounds like its about to power off but the blue light goes off and the red just blinks twice then stays solid.
    If I unplug the y-sus it powers up with solid blue light but obviously no picture.
    Does this sound like a power board issue or y-sus?
    Any help is much appreciated.
  • flocko
    • Nov 2012
    • 1121
    • uk
    Re: Philips 50pfp5532d stuck on standby
    I would say Y-Sus and Y buffers this has the Samsung boards and PDP the same as PS50Q96/7 model, check for shorts on all heat-sink mounted components and drivers, and buffer IC s its normally the top one that fails ? lots on here about these Flocko
    • Hughes07
      • Jul 2013
      • England
      Thanks for the advice, sure enough there's a blown chip on one of the buffer boards, both sus boards have a bulging cap as well. Ordered a new buffer board to give that one last go.
        DON'T install the Y-buffer until you have checked the Y-main or YOU WILL KILL the new buffer if the Y-main is bad!
        • flocko
          • Nov 2012
          • 1121
          • uk
          Hi the problem with these board are that if you replace the buffer board and the Y-Sus has a fault it will blow the new buffer, you need to check the Y-Sus board for shorts , this could then be checked by seeing if the set powers up with out the buffers connected to the Y-Sus , there is a small green LED on the Y-Sus if this is on that is showing that a fault is on this board, not that it is working, that's Samsung arse about face way of doing things? Hope this helps ,there is a guide on here about checking the buffers and Y-Sus that comes from Andy at Ohms if you put the LJ92-xxxxx in you might find it. Flocko
            Some diagnostic info on these boards:
            (Samsung panel used in Philips sets)
            • alro7779
              Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
              by alro7779
              Hello, guys!
              The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
              09-14-2025, 12:25 AM
            • G33RT
              Philips 8200 series 65PUS8204/12 stuck at Philips Logo
              by G33RT
              Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
              It does power up when pressing the power button.
              I already try the power button while plugin the plug with no result.
              Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
              Could this be an PSU or eMMC issue ?
              07-19-2025, 03:43 AM
            • lepak06
              TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
              by lepak06
              Hello
              I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
              The TV is faulty with stuck in Standby RED LED. Can't power the TV.
              Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
              All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
              But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
              01-12-2023, 01:43 AM
            • Bad_IC
              Philips TV 37pfl5604h/12 no standby voltage
              by Bad_IC
              I have a problem with this TV, the standby voltage is not present. I have checked the components around the IC fsq510's area and they seem to work, also replaced this IC but the problem persists.
              These are the voltages in some pins of IC fsq510:
              Vcc=18v
              D=320v
              Vstr=154v
              Unfortunately, I couldn't find the schematic
              What else could I check?
              Is it possible to provide standby voltage from an external source to allow the TV to turn on?
              Thank you​...
              11-08-2024, 01:07 PM
            • toty79
              Hisense LTDN50K220WSEU stuck in standby
              by toty79
              Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
              As per Hisense tv title LTDN50K220WSEU stuck in standby
              PSU rsag.820.5687 HLL 4855WF
              Main rsag 7.820.5842
              I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
              05-01-2022, 04:39 PM
