New tool, Aoyue 8800! Desoldering just got easy!
  • lookimback
    • Aug 2013
    • 1489
    Re: New tool, Aoyue 8800! Desoldering just got easy!
    Decided to fix this one more time. I'm going to turn the temp down to 350°C and see if it will last. It's obviously a terrible design if you can turn it up so high that the element will burn out. I'm wondering if they screwed up on the sensor circuit and it's not reading right. I should probably get a tip temp tester and then, if it isn't reading accurately, I could probably modify it.
    ------------signature starts here------------
    • alex987
      • May 2015
      • 11
      • italy
      #142
      Mine is still working...
      • tibimakai
        • Jan 2012
        • 3680
        Maybe there is no sensor circuitry at all. (like in the fake phones, the software is there though, to show changing numbers)
        • lookimback
          • Aug 2013
          • 1489
          I got it heating again, but no vacuum. I forgot about the cracked pump housing. Can't find a replacement. Might have to modify it and add an external pump.
            • 31187
            patch the housing with rubber compound - you have nothing to lose trying.
            • lookimback
              • Aug 2013
              • 1489
              I tried using silicone adhesive. It might work. Too bad I don't have a 3D printer. The thing that really pisses me off about this is that the typical repair parts which a person might need are not available. I'm still going to buy the Hakko one, but right now I have other obligations. I'll coat the entire thing in silicone if I have to.
                • 31187
                can you post a foto?
                btw if this the the clone type with a pump in the base, i'v seen spare pumps sold cheap.
                • lookimback
                  • Aug 2013
                  • 1489
                  I'll do a teardown this weekend and post pics.
                  • alex987
                    • May 2015
                    • 11
                    • italy
                    #149
                    No wait!
                    Contact Aoyue support via skype:
                    http://www.aoyue.com/en/contact/
                    they have ALL replacements for this unit (not only what you can see on their website!)
                    • lookimback
                      • Aug 2013
                      • 1489
                      Here's the pics of the pump. I don't have time to do the full tear down like I wanted to.
                      • lookimback
                        • Aug 2013
                        • 1489
                        Originally posted by alex987
                        No wait!
                        Thanks Alex. I'll contact them tomorrow and see if they have it. Although it would have been cool to mod it into a station instead of a portable. Easy too. There's already a port on the bottom of the handle for the vacuum hose, and if the 24v for the motor comes from the power unit (I think they do), it would just be a matter of splicing the motor wires in the unit, and cutting them in the power box to connect to the motor. Unless the 24v is rectified and filtered in the gun, then it would require either making a board to do that, or adding a pair of wires from the gun to the new external pump. Either way, still easy.
                        • alex987
                          • May 2015
                          • 11
                          • italy
                          #152
                          ... Unless the 24v is rectified and filtered in the gun...
                          If I well remember, the external power unit carries 220V (for the heating element) and 9V (for the pump), both AC.
                          • lookimback
                            • Aug 2013
                            • 1489
                            You guys have 220v mains though right? We have 120v.
                            • alex987
                              • May 2015
                              • 11
                              • italy
                              #154
                              TIP:
                              Before starting a desoldering job, ALWAYS wet the yellow filter pad with water, in order to allows efficient air passage and filter action (filter pad must become "soft").
                              You should repeat this often, if your desoldering session takes too long.
                              >>If you don't do this, you risk to strain the motor, damaging it<<
                              • lookimback
                                • Aug 2013
                                • 1489
                                I didn't think you were supposed to wet it. I'd tried it once and it seemed to kill the vacuum. Of course, this also has the cracked pump, so it probably didn't have much vacuum to begin with.
                                I emailed Aoyue about it. They sent me an email the next day asking for more information. They want the serial number, pictures, and name of the vendor I purchased it from. I'll get all of that for them this weekend. It would be great if I could get them to send it for free. I'm definitely going to let them know I've already had to replace the heating element twice.
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 5035
                                  • New Zealand
                                  #156
                                  That's more than I would have expected. I hope they sort it out.
                                  -David VanHorn
                                  • alex987
                                    • May 2015
                                    • 11
                                    • italy
                                    #157
                                    I read this in Aoyue 474A+ manual (very strange they forgot to write it in 8800 manual, too).
                                    I hope Aoyue will replace your unit for free. In this case, thumbs up for Aoyue.
                                    • rex98
                                      HP DMI Tool
                                      by rex98
                                      HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
                                      DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
                                      The DMI Tool given here are for personal use only.
                                      DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
                                      You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
                                      from it, and that you please credit the author...
                                      07-02-2025, 05:51 AM
                                    • salim5566
                                      loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                      by salim5566
                                      Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                      06-26-2025, 03:25 PM
                                      by sam_sam_sam
                                      03-31-2024, 02:12 PM
                                    • shamsudeen
                                      Epson M3170 Monochrome inkjet printer adjustment program tool
                                      by shamsudeen
                                      Epson M3170 Monochrome inkjet printer adjustment program tool.
                                      Hi, i want to reset a epson reset program tool needed to reset the EPSON M3170 PRINTER's Maintenance box,
                                      anyone having it, please share
                                      Thank you
                                      07-08-2025, 06:42 AM
                                    • tony359
                                      Best tool to place electrolytic SMD caps on a board
                                      by tony359
                                      HI all,
                                      I am working on some boards where all 100+ SMD caps have to be replaced (yes, they actually went bad!). I found a workflow to remove them comfortably (two irons, pre-heater and extra hot air for larger ones on ground planes).
                                      When it comes to soldering them back, I add solder to one pad and then I use a plastic tweezer to keep them in the right place while I solder that leg.
                                      The tweezer works - but I was wondering if there is a more "dedicated" tool or whether someone has a better idea. If it was for a bunch of caps then who cares. But because...
                                      01-28-2024, 06:23 AM
