Magnavox 32MF338B/F7 has no power, blown fuse
  • SurrealMustard
    • Jan 2015
    • 486
    • The United States of America
    This Magnavox 32MF338B 32" LCD television recently stopped working. No power light, nothing. Further inspection revealed the fuse by the mains input on the MUT board was blown. I can't see any obviously damaged components on either that or the MTS board. It's kind of tricky because the power supply stuff looks like it is split across the MUT and the MTS. Any ideas as to how to nail down where the problem lies?
    Re: Magnavox 32MF338B/F7 has no power, blown fuse
    Disconnect the red/black cable between the main power supply/inverter board and the sub power supply board, then check the resistance between the Source and Drain pin of the power MOSFET mounted on the heatsink and the main rectifier diodes of the main power supply/inverter board (where the main AC fuse is) to see if it shows low resistance.
    Then check the S and D pin of the sub-power supply board power MOSFET.
    • CapLeaker
      Leaking Member
      • 8186
      Don't forget to look at the back side for SMD diodes that might be shorted at the secondary.
      • SurrealMustard
        • Jan 2015
        • 486
        A closer look
        I checked the four diodes at the bottom of the board, and the one at the bottom right does indeed appear to be no good, while the other three test normally. I was able to rule out the possibility of problems on the MTS board by checking with a second, working MUT board on the television.
        Finally, I tried to test the MOSFET. I attempted the instructions shown in the "how to test MOSFET" videos online where you put the black lead on the right leg of the MOSFET, the red lead on the middle one, touch the red lead to the left one, and then check the reading again on the middle one, but got nothing. I got the same thing on the working board though, so maybe I'm just not doing it right (I did look up the documentation for the component to make sure the legs were in the standard GDS order).
        TL;DR? Bottom right diode was bad, MTS board was confirmed good, MOSFET test was inconclusive.
        I didn't see any, but I'm not real familiar with what they look like. Are the components in the picture labelled "E02", "289", and so on examples of surface mount diodes?
        • CapLeaker
          Leaking Member
          • 8186
          There are non on that pic.
          • SurrealMustard
            • Jan 2015
            • 486
            Diode question
            I guess I should start with diode replacement. Any ideas as to how to find out what kind I need? The one in question is mounted facing downward, so I'm unable to read the markings on it.
            • CapLeaker
              Leaking Member
              • 8186
              Which diode is bad?
              • CapLeaker
                Leaking Member
                • 8186
                Btw before you label a component bad, always take it out of circuit or lift a leg and measure again.
                • SurrealMustard
                  • Jan 2015
                  • 486
                  Follow up
                  Which diode is bad?
                  The one in the bottom right of the cluster of diodes toward the bottom of the board.
                  I will have do that and check it again when I get the chance.
                    "The one in the bottom right of the cluster of diodes toward the bottom of the board." IN which pictures? The two pictures in POST 1, or in post 4?
                    • SurrealMustard
                      • Jan 2015
                      • 486
                      Components
                      The first picture in post 1; I should've been more specific.
                        Those 4 rectifiers by the white power resistors (fusible resistors) are the bridge rectifier for primary side of the circuit.
                        So the power MOSFET on the heatsink next to the resistors is OK, no low resistance between S and D for sure because that is the commonly failed mode on this two transistor cheaply made switching power supply.
                        There are many parts that will fail in the primary side of the circuits.
                        Service manuals:
                        http://elektrotanya.com/?q=showresul...at2=schematics
                          Power supply diagrams.
                          • CapLeaker
                            Leaking Member
                            • 8186
                            Lets say, if only that diode and the fuse blew, than you're lucky. My experience with these types of sets has been that there is much more gone than one diode and a fuse. Btw, I'd like to see a shot of the whole power supply / mainboard combo of the back side.
                            • SurrealMustard
                              • Jan 2015
                              • 486
                              Hopefully we can get to the bottom of it. Here's a photo of the entire bottomside of the MUT board in the attachment.
                              • CapLeaker
                                Leaking Member
                                • 8186
                                Make yourself a new jig, you might need it. Basically it is a light bulb in SERIES with the power cord. So if there is still something shorted on the primary, all that is going to happen is that the light bulb glows bright. I used a 100W light bulb. Remember to hook it up in series! You also could solder a couple of wires on to the bulb and jam that with the blown fuse into the fuse socket. This way you prevent any further damage and the new parts you just put in wont blow right away up again.
                                http://www.repairfaq.org/samnew/tvfaq/tvtslbt.htm
                                On the backside of the board, measure the 4 diodes on top center for shorts. Other than that, you have to start lifting stuff at the primary until the short is gone (that is the primary objective right now), then verify other components if they are still good.
                                  This is one of the version I made:
                                  https://www.badcaps.net/forum/showpo...&postcount=112
                                  • CapLeaker
                                    Leaking Member
                                    • 8186
                                    Looks almost the same as mine!
                                    • SurrealMustard
                                      • Jan 2015
                                      • 486
                                      Woah
                                      That looks pretty advanced. I don't know if I have the spare resources or know-how to build something like that. Is there any other way to find the bad components?
                                      • SurrealMustard
                                        • Jan 2015
                                        • 486
                                        The moral of the story
                                        I guess I'll keep my eyes open for a power supply then. I bought the very last one available from the very last store that had it in stock a week or two ago only to find that it was broken. When I asked "Electron Resort" for a refund, they said, "fill out this form and tell us exactly what components are broken. Then, you can pay your own return shipping and give us a restocking fee". WHAT?! Why should I have to diagnose their bad item? Why should I have to pay return shipping? More importantly, why is there a "Restocking fee" for something that shouldn't be restocked or stocked at all? Thankfully, payment was made through PayPal, and as annoying as PayPal can be, they can be remarkably effective at taking care of crooks like "Electron Resort". We now have a full refund and Electron resort once again has a broken MUT board for sale to scam a few more people who aren't familiar with the power of PayPal.
                                        TL;DR? DON'T EVER SHOP AT AN ONLINE STORE CALLED "ETVPART.com" OR "ELECTRON RESORT"!!
                                        With that out of the way, does anyone know where I can get a new MUT board for this thing since we can't nail down exactly what components are bad?
                                        • beetle1303
                                          Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                          by beetle1303
                                          I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                          On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                          01-13-2025, 08:49 PM
                                        • Babbar
                                          by Babbar
                                          04-12-2024, 01:12 AM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
