32LX1D dual tuner problem
  • instarep
    • Jul 2014
    • 28
    Hi, thank you for your help. Your site has been very helpfull for me since now.
    Dual tuner (antenna/cable) When i connect antenna i get a perfect image.
    HDMI input works perfectly too.
    When i connect the cable module to the cable entry i get noise in the image or more vertical line of noise. I get the same problem when using the cable module in the antenna connection.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8212
    Re: 32LX1D dual tuner problem
    Try that cable box on another TV.
    • SteveNielsen
      Retired Tech
      • Jun 2012
      • 2327
      Also, have you tried a different coax cable at the cable entry?
      • instarep
        • Jul 2014
        • 28
        Disconnected the cable from my TV which was fine and connect direct to this one. Problem is the same at customers house. So not a bad cable or cable box. thanks for the suggestions!
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8212
          You tried a different cable, but did you hook up the cable box to a different TV? Did you verify you don't have any RF leaks up the pole on the splitter? Pretty easy to find with a TDA and spectrum analyzer.
          • nicholas1110
            • Aug 2012
            • 127
            • usa
            I've had the same issue on several on these and the 26" versions. The fault was evident also on composite input and the VGA input. I suggest trying those inputs as well. I never did resolve the issue as the customer never wanted to spend any money on replacement board. I have a suspicion it is related to the analog section of the main boards
            • instarep
              • Jul 2014
              • 28
              Thank you guys, yes the cable box was hooked up on my personal TV and working great before doing the test on the defective tv.
              I appreciate your input Nicholas1110, i will try other inputs as mentionned. i'll let you know...
              • instarep
                • Jul 2014
                • 28
                Can't find any schematics for this tv... Anyone?
                • theone111
                  by theone111
                  3. Problem: TV shuts down
                  07-22-2024, 10:36 AM
                • howardc64
                  by howardc64
                  Problem
                  08-04-2024, 10:36 PM
                • Zeonalbasta
                  Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                  by Zeonalbasta
                  i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                  The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                  09-13-2024, 01:17 PM
                • Rick_1234
                  by Rick_1234
                  Good evening, gentlemen.
                  Things I tried
                  06-22-2024, 04:44 PM
                • Gibon378
                  Problem with stopping audio and video for no reason
                  by Gibon378
                  PC Specs:
                  • CPU: Ryzen 5 1600
                  • GPU: GTX 1080 Palit JetStream
                  • MOBO: ASRock ab350 PRO4
                  • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                  • PSU: XFX 650W (don't remember what model)
                  • OS SSD: ADATA SP920
                  • OS: Windows 10 21H2
                  Problem description:
                  Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                  11-19-2022, 09:41 AM
