Panasonic TC-P54 Doornail Dead
  • Michale32086
    • Nov 2011
    • 1453
    Seems to be my week for Panasonics...
    I just got in yesterday a nice Panny TC-P54 Unfortunately, I left the back at the shop (working from home today) and don't have the rest of the Model Number..
    This unit does not power up. Does not light up. Completely dead.. The only thing I notice is a slight power hum in the vicinity of the Power PCB when I plug in the unit..
    Right off the bat, I noticed some differences from the last Panasonic.. There doesn't appear to be any VS or VA connections. Further, no voltage label on the back of the display. There IS a VSUS TP and a VDA TP on the power PCB, but that is all I can find.. There are a few TP posts scattered through out the Power PCB, but only the VSUS and the VDA are marked. There is 0V on the VSUS and VDA points.. The only voltage I have confirmed is the incoming voltage of 120v AC...
    I grabbed some manuals from Toms Place (thanx Tom! ) but none of them match this set exactly...
    Any thoughts on my next step?
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P54 Doornail Dead
    most likely Tc-P54g25. remove the SC2 and sc20 leads and see if any changes
    don't reconnect after shutdown, if it powers up. vsus can be measured at either p2,sc2 ss11 or p11, 203v or so i think. get use to no labels from 2010 on.
    • Michale32086
      • Nov 2011
      • 1453
      Disconnected SC2 and SC20 (pic)
      Still dead...
      • tw2005
        • Oct 2011
        • 6458
        Still dead...
        I was jumping the gun a bit. sounding like A board but i'd check across sc2 for short as these have a habit of blowing the SC shorting Vsus. A7 pin 1 is 5v stb, any life there?
        • tw2005
          • Oct 2011
          • 6458
          manual
          2 downloads / day with no login
          • Michale32086
            • Nov 2011
            • 1453
            manual
            Yep, found it. Google?? Amazing.
            Lemme check the points you mentioned..
            • Michale32086
              • Nov 2011
              • 1453
              No short on SC2..
              Pin 1 A7 shows 5v
              • tw2005
                • Oct 2011
                • 6458
                • tw2005
                  • Oct 2011
                  • 6458
                  p59 is probably a good place to start. Know any history on the TV as to what happened
                  • tw2005
                    • Oct 2011
                    • 6458
                    so basically, plug in to power relay clicks, if no then check 5v, you have that, then disconnect k board in case it's shorted, if still dead = A board
                    I guess check the SD slot for foreign object shorting board(coin)
                    • Michale32086
                      • Nov 2011
                      • 1453
                      Nope.. Came in blind to the shop... Guy wanted it fixed, I estimated about $150.. He said scroo that, so I gave him $50 for it..
                      I checked the manual you posted.. Awesome, thanks!
                      I checked for a short on the P15V line. All the connectors pulled and still dead.. But I noticed that the page (Slide 10) said P25
                      If a short is found on the P15V line, remove connectors P6, P11, P25, and SC20 one at a time to determine which board is defective.
                      The P25 Connector is empty. No cable.
                      • Michale32086
                        • Nov 2011
                        • 1453
                        Nothing in the SD card slot... That woulda been kewl if that's all it was..
                        Disconnected all P connectors.. Plug in, nothing happens. No relay click no nuttin...
                        Bad Power PCB??
                        • Michale32086
                          • Nov 2011
                          • 1453
                          Going thru the manual you posted for Detailed Troubleshooting for Shorts..
                          • tw2005
                            • Oct 2011
                            • 6458
                            generic guide, I think P6, P25 no use labelled in the manual. But did you find a short? if not then all that is meaningless. It's the F15v that needs to be activated for the relays to click, the 5vstb is used to produce 1.2v, stb3.3v which is also used to power the standby LED. So 5v stb but no front LED and no relay clicks is A board. You may find one for $150
                            • tw2005
                              • Oct 2011
                              • 6458
                              should be either TNPH0834AF or TNPH0834AD depending on whether it's a G20 or G25.
                              I guess you have no other 2010 fhd A boards laying around, any size TV would do.
                              • Michale32086
                                • Nov 2011
                                • 1453
                                According to the Troubleshooting (Slide 12), if there is no short to ground on pin 1 of P2 and no short to ground on pin 1 of SC2, then replace the SS board..
                                Am I reading that right??
                                • Michale32086
                                  • Nov 2011
                                  • 1453
                                  I looked yesterday when this first came in. No compatible boards on my boards shelves.. I might have some compatible units awaiting dis-assembly in the sheds...
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    you're reading it right but not using it right. those are procedures for when you have found shorts i.e. you have a shorted line but now need to drill down to what board.
                                    That brings me back to what i said earlier, have you found shorts?
                                    The Tv is dead,has 5v stdby, no LED, no relay clicks from what i'm reading.
                                    A board
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      any g20/g25 should be able to plug in and at least see if the stdby led and relay clicks, could turn it on but picture will be wrong but at least confirms A board
                                      • Michale32086
                                        • Nov 2011
                                        • 1453
                                        Nope.. No shorts on P2 or or P11 or SC2.
                                        A board
                                        Yep, dead TV, 5v STBY is present, no relay clicks, no LED...
                                        A Board it is...
                                        Not the best news in the world, but at least it IS news.
                                        Thanx
                                        • Buzztv
                                          Panasonic TC-P42S60 Plasma,how to check Vsus
                                          by Buzztv
                                          This is my first post in attempting to keep my beloved 2013 Panasonic plasma tv going.
                                          About 6 weeks ago the tv was turned on but then immediately shut off. There was no recent power surge or popping noise or any other symptom.
                                          I checked all of the obvious things and decided to try a replacement power supply board (PSS in Panasonic lingo).
                                          I would like to check the Vsus but this is one of the final models and at that point Panasonic did not indicate the Vsus and Vad voltages inside the chassis. It looks like they were discouraging people from making adjustments....
                                          10-27-2019, 01:24 PM
                                        • badcappo
                                          Dead Panasonic Viera TX-P65STW50 Plasma TV
                                          by badcappo
                                          Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
                                          Diode type G972s6 - D101 with a short
                                          Mosfet 06N90E - Q301 shorted
                                          Fuse T5AH 250V - F103 blown
                                          Diode D301 shorted
                                          Relay DG1U-17VDC II - RL001 blown
                                          I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check πŸ˜€...
                                          11-24-2024, 11:27 AM
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                                          11-20-2024, 08:52 PM
                                        • Super360
                                          Panasonic TC-P50G10 DEAD
                                          by Super360
                                          Hi everyone I have a plasma here that is absolutely dead no power light. When I press the power button the relays click the fan spins for a second then it's dead and nothing happens on the screen. Anyone have any suggestions?
                                          12-27-2021, 11:40 AM
                                        • double_DD
                                          How can I be sure that my EC chip is dead?
                                          by double_DD
                                          As the title suggests, how can I be sure that my EC chip is really dead?
                                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                          03-12-2025, 07:47 AM
