The tv would turn off after about 20 minutes of being powered on, although the picture is quite good when running. I took it apart and replaced 6 bulging on the power supply. All were 2200uf 10v, and I replaced them with new panasonic caps. I checked the Vs and Va, both are fine. I read about some cold solder joints, so I touched up quite a few solder points. The tv will still turn off after about 20 minutes or so.
Also, right after I replaced the caps, the tv stayed on for a good 2 hours or so until I turned it off. I figured this was a good test and put everything back together and moved the tv back upstairs. It is much cooler in the basement. Does the power supply have some sort of overheat protection? I'm lost.
