LG 42LN578V picture but no backlight
    Re: LG 42LN578V picture but no backlight
    correct but with it being a led tv i was wondering if you could purchase the inside layer
      What do you mean inside layer?
      If the LCD is cracked its cracked.
      Difference with LED is just the backlighting
        ok m8 thanks
          The LED layer itself is the front layer its around 3-5mm in thickness. Behind that is just a plastic sheet that is used as a diffusion material for the led's to spread the light uniformly. There are then lots of acetate type layers behind that. It would be possible to transplant a working LED as I did using a set with a failed backlight but these are much harder to source than those with broken screens. I was lucky that I had a failed backlight, had it have been a broken screen the TV is near worthless.
