LG 42LN578V picture but no backlight
+ More Options
Posts
  • sordids999
    • May 2013
    • 2149
    • uk
    Re: LG 42LN578V picture but no backlight
    correct but with it being a led tv i was wondering if you could purchase the inside layer
    • newtothis
      • Mar 2013
      • 1556
      • england
      What do you mean inside layer?
      If the LCD is cracked its cracked.
      Difference with LED is just the backlighting
      • sordids999
        • May 2013
        • 2149
        • uk
        ok m8 thanks
        • nikonite
          • Oct 2014
          • 10
          The LED layer itself is the front layer its around 3-5mm in thickness. Behind that is just a plastic sheet that is used as a diffusion material for the led's to spread the light uniformly. There are then lots of acetate type layers behind that. It would be possible to transplant a working LED as I did using a set with a failed backlight but these are much harder to source than those with broken screens. I was lucky that I had a failed backlight, had it have been a broken screen the TV is near worthless.
          • triplefour
            by triplefour
            09-13-2023, 10:43 PM
          • TR103
            by TR103
            - it keeps rebooting
            01-22-2025, 04:12 PM
          • Mgiffune
            by Mgiffune
            I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
            I ordered a supposedly β€˜new' Tcon board this time, and
            06-09-2024, 10:28 AM
          • Ierwin
            by Ierwin
            05-13-2025, 03:31 PM
          • groomit
            Philips 50PUS7363/12 Backlight but no picture
            by groomit
            I'm having trouble with above mentioned TV. Bought it defect.
            Picture was heavily compressed around the horizontal axis. Fiddeled and tried different things (mask clock lines, swap T-Con). But no difference.
            Then I identified a heating capacitor on the left hand Signal-PCB (?) below the display. Replaced it by hand soldering. Checked for shorts afterwards. But now the screen stays black.
            I can see backlight, but screen stays black.
            What I've tried:
            - Disconnect right side cable from T-Con -> same (backlight but no pic)
            - Disconnect left side...
            11-22-2024, 02:43 PM
