Samsung LN32A450C1D: Bad T-Con or panel?
  • jaimegmr
    • Dec 2004
    • 17
    I have a Samsung LN32A450C1DXZA with lines and duplicate images.
    A side issue I had was that I powered on the TV when it had been left out and condensation formed on it. There was a short from a jumper to a capacitor (this seems to be a common problem with this power supply. I saw one in worse shape on another forum.) I fixed the damaged jumper and the TV still powers on. I was planning on replacing the bulged capacitors but now I dont know if it is worth it.
    I opened up the panel and pushed on the flex ribbon cables but nothing changed. I am reading 11.75V at the T-CON board coming in from the main board. Is this too low for the T-Con board?
    Considering there is about a 1" strip on the very bottom of the TV that works correctly, it makes me think that the panel is the one that is bad since I don't see how a bad T-Con board can only fail on part of the image.
    • 12323
    • U.S.
    Re: Samsung LN32A450C1D: Bad T-Con or panel?
    kind of hard to tell, but caps are pretty reasonable and not too hard to put in, I would try that.
    • Ltank
      • Jun 2013
      • 776
      Looks like a bad screen. The varistor would not cause the display problem
        • 12323
        • U.S.
        that one solder joint there looks a little funky, maybe touch it up a little.
        • kca
          by kca
          Hello all ~
          08-31-2025, 06:38 AM
          09-07-2024, 05:50 AM
        • netgearnetgear
          TCL 43S423 TCON OR PANEL FAULTY???
          by netgearnetgear
          Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
          08-20-2025, 06:04 PM
        • x_orange90_x
          TCL 50S535 bad tcon or panel issue?
          by x_orange90_x
          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
          03-29-2025, 11:02 PM
        • advant
          by advant
          02-03-2020, 12:25 AM
