Sharp LC48LE551U
  • simcole
    • Apr 2014
    • 30
    Sharp LC48LE551U
    Hello everyone. Long time reader, but I think this is my first repair question. I've fixed about 12-14 TV's so far thanks to these forums as a hobby. So I have a weird main power board for a Sharp that I need some advice on.
    The TV does not show any standby voltage when it's plugged in. This board has some weird names for the power connector that I don't know what it means (blu_on).
    Anyway plugged in and off here are my voltages on the power board:
    Pin 10 - Dim2 - 0v
    Pin 9 - Dim1 - 0v
    Pin 8 - Blu_on - 0v
    Pin 7 - PS on - 0v
    Pin 6 - ground
    Pin 5 - ground
    Pin 4 - ground
    Pin 3 - 19v - 18.6
    Pin 2 - 19v - 18.6
    Pin 1 - 19v - 18.6
    I'm GUESSING Blu_on is my 5v? What's that stand for?
    Here is a picture.
    What do I test now? I haven't been able to locate the service manual yet. Thanks in advance for all your help.
    Re: Sharp LC48LE551U
    BLU = Backlights ON.
    This LED Backlights TV may use 19V STBY.
    Can we see the whole backside of the TV so we can see how all the boards are connected together?
    Also need clearer pictures that are in focus.
    • simcole
      • Apr 2014
      • 30
      Here is a photo. I'm trying to get this thing in focus. I need to wait until daylight to get some better lighting. If this used 19v standby then maybe the main is bad somewhere.
        Sigh, another example of the "clone wars"; a Sharp branded TV that's not made by Sharp, but the lowest bidder in China.
        • simcole
          • Apr 2014
          • 30
          Does that mean nobody can help? I could really use a little guidance as searching here for a similar design has turned up nothing and since I can't find the service manual.
            Right now it points to the problem on the main board, it is not sending command signals to turn on the main power supply.
            You can try and see if the main board has any fuses, 3-PIN Voltage regulators C that need to be check, also try disconnecting the cable to the T-CON board and see what happen.
            • simcole
              • Apr 2014
              • 30
              Wow, thank you for the response. I though I was on my own. Anyway, there are no fuses or 3pin VR's on it. I disconnected the T-Con and nothing happened. I checked voltages on P_ON and BLU_ON while pressing power, nothing happened. I suppose it might be time to buy a new board, but I wish there were something else to check first. Any last ideas anyone?
                • 12206
                • U.S.
                like Budm says, sure looks like a mainboard issue, they can be a bear to trace down to component, a new board is probably the way to go.
                • mkdj
                  Acer TravelMate P214 - N19Q7 main power rail shorted to ground
                  by mkdj
                  Dear all,
                  I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
                  I have checked resistance across each of the 4 MOSFETS. I have the following readings:
                  Both N-Channel Mosfets: nothing odd
                  P-Channel MOSFET number 1:
                  source - drain : 117 kOhm
                  source - gate: 96 Ohm
                  gate - drain: 117 kOhm
                  P-Channel MOSFET...
                  Today, 06:08 AM
                • barry101
                  Apple 820-3662 VCore shorted to ground.
                  by barry101
                  Hi, Would appreciate some help.
                  I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                  Get charger light but no fan spin or chime. No liquid damage.
                  Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                  Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                  With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                  Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                  06-24-2025, 07:34 AM
                • advant
                  by advant
                  02-03-2020, 12:25 AM
                • sefoster
                  Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                  by sefoster
                  I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                  11-20-2022, 09:29 AM
                • gavenb
                  Sharp LC-80LE661U 80 inch
                  by gavenb
                  Hi folks!
                  I have a LC-80LE661U that had some interesting issues.
                  Initially, it would come on and show the sharp logo and would show normal static before shutting off.
                  I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
                  11-12-2023, 02:05 PM
