Re: Dead As A Doornail. Sony KDL-40EX400
Checking all the pins with the cable connected gives me the 3.3v on standby.. I am guessing when I checked them before I wasn't making contact with the pin, as I was just using the probe tip..
This time around, I used a straight pin hooked to the probe to insure contact...
"The only standby I could find was 3.3v
Checked the marked pin and it did give me 3.3v at plug in"
So you are saying that there was no Voltage what so ever when all the boards are connected, and now you do have 3.3VSTBY when the cables are disconnected from the power supply board.Leave a comment:
Yea, Tom's idea might shed light on that. But it will have to wait til I get to the shop.. I have no resistors here at home..Leave a comment:
dunno, it seems like the mainboard isnt turning on the power supply.Leave a comment:
It was out.. But here are the voltages with the connector plugged in..
All the unmarked pins are 0vLast edited by Michale32086; 02-09-2015, 09:25 AM.Leave a comment:
You can usually check power supply operation by connecting STBY and POWER ON with a small resistor (100 to 470 ohms, 1/4W through hole type)Leave a comment:
thats good, are your other voltages correct too?Leave a comment:
Checked the marked pin and it did give me 3.3v at plug inLeave a comment:
maybe try unplug the connector from power supply that has stndby, and measure the stndby pin on power supply in dc mode.Leave a comment:
I seem to remember a problem before similar to this where the MainBoard was the culprit..Leave a comment:
Yes, since this PSU uses Active PFC, the cap voltage will boost (typically to 380-400V)Leave a comment:
wonder if this could be a bridge rectifier issue?Leave a comment:
Yea, should have clarified that..
That's what I get when I plug the TV in.. Pushing the power button has no effect.. Still reads 166vLeave a comment:
OK, I get 166V on the large cap which is a 270uf 450V cap...Leave a comment:
I also am ready to check the voltages on the large cap.. Just wanted to make sure the setup I have (pic) is good..Leave a comment:
by thstuffA) TV initially dead
B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
C) Was able to perform a Reset from Settings menu and completed out of box configuration.
D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical... -
by bohabohaHello to everyone in this wonderful forum.
I have this SONY LCD TV KDL_46R473a
PSU GL5 APS350 :1-888-122- 12
MAINBOARD FY13_EU IP-012C101-4010
black screen ,no STB no life almost death.
on PS all the required volts are present 394V on the main cap and those on cold side 12.41V,3.45 and 3.45 are on
Also 3,5,and 12v are on.
nothing happens if i disconnect the PSU from the mainboard as on Samsung because here i think the mainboard gives the signal to the ps.
don't know what to do next all suggestions and advice are very welcome​... -
by TalynHi,
My Sony W905 started to turn itself off an on every few minutes and blinking 8 times red in standby. A few minutes later the tv was completely dead.
I can only hear the click of the PSU when attaching/detaching the power cable. No standby LED.
Any advice? Thanks! -
by mrsithHello again lifesavers.
I have a KDL-55W755c that came in dead - not even standby light going on. Tested the power supply - all correct. Tested the output pins on the Led driver board (in which the power cord plugs in) - all seemed fine.
I got a service manual for this model and tested the DC/DC converter by checking voltages on selected components. Every voltage was present where it should be. Service manual says that in this case a "Muffin" replacement is needed. This is the moment where I got stuck as I wasn't able to Google my way through it - till this day I... -
by Carlos#2003%Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
Channel: Schematic Requests ONLY!
- Loading...
