Vizio E371VL power or inverter issue
  • johnnyospot
    • Feb 2015
    • 14
    I have two Vizio E371VL tv's that were among 4 TV's that went down after a nearby lightning strike.
    When I plug the set in, the Vizio logo glows orange. When I power the set on, the logo turns white, but there is no picture or sound. I do not see the backlights working either. The only way to turn the set off is to unplug it.
    Fuses all test ok.
    I measured the large Cap, and it had 391V, all the capacitors look fine... in fact I don't see any heat damage or any component damage at all to indicate a problem...
    On the ribbon I had
    VBR_B....................3.23V
    STATUS...................0.0V
    INV ON/OFF.............0.0V
    REMOTE ON/OFF.......3.23V
    12V.........................12.08V
    GND........................0.0V
    5.1VSB....................5.0V
    It seems there is a problem in the inverter somewhere, but what should I look for and on which board? as best I can tell it doesn't appear to be the EEPROM problem that seems to come up, or the Capacitors getting fried, but I could be totally wrong...
    Any thoughts?
    Thanks in advance to all!
    Re: Vizio E371VL power or inverter issue
    "INV ON/OFF.............0.0V" The main board is not sending the on command to turn on the backlights so main board is not functioning.
    " The only way to turn the set off is to unplug it." That means you have problem some where on the main board.
    • pocketwatch62
      • 74
      • US
      Check regulator up13 on the main board..
      • CapLeaker
        Leaking Member
        • 8211
        ... and or there may be a bad surface mount cap that has physically no bad sign from the outside.
        • johnnyospot
          • Feb 2015
          • 14
          up13 measures...
          IN.....3.29V
          OUT...1.19V
          ADJ...0.0V
          tab....1.19V
          any suggestions as to which Surf Mount Cap 's to look at? I'll start looking at all of them, but if theres any to narrow it down, I won't complain, lol!
          Thanks again for the help folks!
            What numbers and letters are printed on that U13? There are more than one 3-pin Voltage regulator CIs on that board that should be checked.
            We need what are printed on the ICs so we can tell what the Voltage output should be.
            SJ sells EEPROM for this model so that can be the problem.
            http://www.shopjimmy.com/catalogsear...q=Vizio+E371VL
            • johnnyospot
              • Feb 2015
              • 14
              I see 3 regulator IC's on the main board...
              UP13...AX1007
              -12
              2051
              IN.....3.29V
              OUT...1.19V
              ADJ...0.0V
              tab....1.19V
              UP3....AX1007
              1462
              IN......3.28V
              OUT....1.48V
              ADJ....0.23V
              tab.....1.48V
              UP14...AX1008
              12101
              IN.....5.15V
              OUT...3.29V(this tab not connected to board, seemingly intentionally)
              ADJ...2.04V
              TAB...3.29V
              I looked up the Datasheets, and if I understand things correctly, then it sounds like UP14 is definitely good, and either UP3 or UP13 is bad... and I'm guessing its UP13...
              Does that make sense? And if that is the bad one, is there something else I should look for that goes with it or, just replace UP13?
                U13 (1.2V fixed reg) = 1.2V, OK (you are getting 1.19V)
                UP3 (adj reg) = 1.25 Vref + 0.23Vadj =1.48Vout = OK
                U14 (ADJ REG) = 1.25Vref + 2.04Vadj =3.29Vout = OK.
                So it is not due to these 3 regulators.
                • johnnyospot
                  • Feb 2015
                  • 14
                  Hmmm... I don't think it's the EEPROM, or at least not just the EEPROM, as the backlights are not working at all, and they should be working if it was just the EEPROM...
                  Looks like more testing to be done...
                  Or is a reflow a good next step? I've never done it before, but I do have access to a high end oven that I could try it...
                  Any suggestions as to where to get best/most detailed directions? is it better to try with a heat gun, or oven?
                  From what I've read, it looks like wrapping the thing in foil except for the main processor in the middle and doing it in the oven might be the way to go...
                    Well, if you understand what the TV needs to have the backlights comes on then you will understand why I am saying you have main board problem.
                    Right now the main board is not sending the ON command to turn on the backlights, if the EEPROM is corrupted (which you have no way to test that EEPROM), or the processor is bad, or etc. then you will not get the command signal.
                    You need to have PS_ON, BL_ON, PWM dim or A dim.
                    Post 1 "INV ON/OFF.............0.0V" So how do you think you will get the backlights when the command signal is at 0V?
                    • johnnyospot
                      • Feb 2015
                      • 14
                      I totally agree it's a main board problem... I just tried the 2 AAA batteries test on the INV ON/OFF pin and it turned the back lights on... so I need to trace the flow back from there-- somewhere on the main board is the problem, it's just that the usual suspects are apparently not guilty so far... I just found another thread...
                      Vizio VW37 Power Supply PSON working but no 12v or 24v output ... I haven't finished reading through it yet, but so far it seems to be the same problem but on an older model... hoping I can find the solution there and apply it...hoping, lol!
                        Those older Vizios are know for having bad regulators problems, the newer E series have EEPROM problem.
                        • johnnyospot
                          • Feb 2015
                          • 14
                          I wish I could just replace the EEPROM... but hesitate as it says under the details for the new EEPROM Chip from Shopjimmy.com...
                          Symptoms EEPROM replacement CAN NOT Fix:
                          - TV turns on but has NO backlight
                          - TV turns on AND backlights are on, but has no video display at all
                          - HDMI issues
                          - Audio issues
                            You can replace the main board then.
                            • johnnyospot
                              • Feb 2015
                              • 14
                              To update anyone interested,
                              I finally got my hands on a replacement Main Board. I tried to reflow the main chip, just to see what would happen, but suspect I need better equipment to do that, as it didn't help any. The new board fixed the problem however, so the challenge is finding another for the second TV. Thanks to all for the help!
                                Thanks for the follow-up.
                                • Sevenqi
                                  • Jul 2011
                                  • 292
                                  I fixed the same TV recently, it's the fuse F1 on the main board broken, replace the fuse everything works.
                                  • GLISIT
                                    by GLISIT
                                    01-16-2025, 02:29 PM
                                  • justice171
                                    Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                                    by justice171
                                    I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                                    Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                                    1. Verified that all critical voltages are present:
                                      • 3.3V and 5V are always present if DC is plugged.
                                      • 1.8V on the BIOS chip is present.
                                    2. Checked the power button functionality:
                                      • When pressed, the voltage drops to 0V, indicating the button is functional.
                                    3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                                      • Confirmed connectivity is intact, ruling out issues
                                    11-26-2024, 12:39 AM
                                  • claws77
                                    lenovo flex 5 14itl05 power sequence issue
                                    by claws77
                                    hi guys, my motherboard will not start no matter what
                                    when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                                    but rest nothing happens no sign of life.
                                    this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                                    with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                                    but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                                    i have no knowledge of motherboards ....
                                    10-20-2024, 02:48 PM
                                  • yaya3gmax
                                    Laptop Power Issue – Works on Battery, Fails on Adapter Load
                                    by yaya3gmax
                                    Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
                                    Symptoms:
                                    • Laptop works normally on a pre-charged battery.
                                    • Battery does not charge when adapter is connected.
                                    • Without battery:
                                      • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
                                      • Speakers “pop” when power cut occurs indicating harsh sutdown.
                                      • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
                                    08-21-2025, 07:16 AM
