Have a Zener Diode with no markings at location D6 ( behind inputs ). What can I use maybe in increments to fill this void? The TV runs until warm and then shuts off. Keep this Zener cold and runs all night. Any help?? I appreciate it.
Zener DIODE HELP D6 - Element F0V87C
Have a Zener Diode with no markings at location D6 ( behind inputs ). What can I use maybe in increments to fill this void? The TV runs until warm and then shuts off. Keep this Zener cold and runs all night. Any help?? I appreciate it.Tags: None -
Re: Zener DIODE HELP D6 - Element F0V87C
something else I was thinking that there's a test for zeners that may indicate what voltage it is if it's possible to keep it functional during the test.
example
http://www.learningaboutelectronics....-a-zener-diodeLast edited by tw2005; 01-30-2015, 02:42 AM.Comment
Since you can make it function by cooling it, if it is Zener Diode the you will put the red probe on the Cathode and Black probe on the Anode since Zener is used in reverse bias mode and look at what it is shown on the meter and the polarity shown on the meter. If it is regular diode then put red on Anode and Black on Cathode, the Voltage then should shows around 0.6~0.8V.
What DC Voltage do you get at the Anode and chassis Gnd, Cathode and chassis Gnd?
The diode is close to other components so how did you cool it down without cooling other components close by?Last edited by budm; 01-30-2015, 09:59 AM.Never stop learning
To be honest I'd suspect the nearby regulator more than a zener/standard diode...Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
So across it is about 0.5V... silicon diode
Drops of coolant, that would conduct and could change the circuit, it's not reliable.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
That means the Diode is in reverse bias because the Cathode (23.5V) is more positive than an Anode (23.0V).
Is this with TV on or TV off?Never stop learning
Not clear, so you are getting 0.5V with reference to GND? or across the Diode (Black probe on Cathode, Red probe on Anode)? Then it is in forward bias.
But what do you get when the TV is not working? There must be different when it is good and when it is bad then.Last edited by budm; 01-30-2015, 03:44 PM.Never stop learning
when testing the TV on. I get .5volts with black on cathode and other end on anode. Reversing gives me -.5volts. Hope this helps. When testing off and testing, I get same results either way. When I reference to ground I 23.5 Cathode and 23.0 on anode.Comment
The means the Diode is not even bias on, it is in reverse bias mode. The question is that you can make the TV works by cooling this Diode which means that it must be showing different reading when it is not working and when it is working, that is what we are trying to find what the readings are.Never stop learning
guess I will try the 4148...not sure what else to do. It says D6 and usually a Zener is ZD. Don't think that should hurt anything? If you think it's a mistake..let me know..no one else has any info on it and schematics are not available. Hate when components are not labeled.Comment
Please do budm's test first. I really do not think it is that diode myself.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
by Vincenzo2My Element 32 inches tv (ELEFW328B) lost it's backlight (confirmed with a flashlight test) and the connector on the PCB (it has one board that has a processor chip, switch mode power supply, and backlight circuit) that has the two wires that go to the backlight LED strips has a very low voltage (28-29 volts) when turned ON, in my opinion.
Started testing components and found an SMD diode or zener that is shorted (even zero fusing resistors read a few tens of milliohms, while this thing reads zero).
I put some pictures here to show that it is labeled "M7".... -
by unimatrix93Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
The led strips has 9 6V leds.
1 Photo -
by sam_sam_samI have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
I bought this from an eBay seller but unfortunately they only had one
I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
I bought three of from them to also make battery packs with this output power limit in mind
I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery... -
by nev1001Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
I think an issue could be a zener diode (or capacitor) which has shorted out.
The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...-
by hobostoveHey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
There's a 22ohm resistor that's melted and open, but it still has the bands.
The other part is a zener diode and it's top went to jesus, so I can't read the marking.
It looks like the diode connects the source and drain of a TNY284... - Loading...
